Cat 318 Engine w/Direct Electric Start
Showing 1 to 10 of 17 results
rogerjmartin
Send a private message to rogerjmartin
Cat 318 skid engine (Serial 345B689) with a direct electric start and has a pre-combustion chamber set-up for glow plugs (but does not have the glow plugs in it, currently plugged but can be put in). Complete as shown, and I do have the electric starter that goes with it. No load Gov. R.P.M. 1900, Full load Gov. R.P.M. 1800. Horse Power Setting, Sea Level 82.5. It is out of a crane. The previous owner said it was running when the crane was scrapped. It has been stored in a box trailer since I bought it.
You can call my cell phone anytime for more pictures, more information, and a price: 937-477-5270. I am located in southwest Ohio. Thanks for your interest. Roger
Sat, Dec 31, 2016 3:35 AM
ag-mike
has 1 of those different looking air filters. i'd like 2 find 1 for a d315. good luck with ur sale.
Sat, Dec 31, 2016 6:11 AM
Andrew
Reply to ag-mike:
What happened to the fuel pump also seen in one of the photos.
Also just out of curiosity where is the starter.
Sat, Dec 31, 2016 9:30 AM
rogerjmartin
Reply to Andrew:
Hi Andrew,
The fuel pump was on another engine that was dropped and broken off before I bought it. Here's a few more pictures of the 318 Direct Electric...including pictures of the starter.
Sun, Jan 1, 2017 1:59 AM
Andrew
Reply to rogerjmartin:
Hi Andrew,
Thanks.
Always interesting to look in the background of shed photos to see what else is laying around.
Sun, Jan 1, 2017 5:36 AM
Reply to Andrew:
Thanks.
That's some odd ball starter to have the external engagement lever like that. At least that's what it looks like anyway.
Sun, Jan 1, 2017 8:13 AM
farmerstu
Send a private message to farmerstu
am looking for a 318 just pooched the one in my 57 d6 what kindof price ya looking for?
Wed, Nov 8, 2017 2:22 AM
Reply to farmerstu:
That's a 45Bxxxx series Industrial engine. Several differences from the tractor D318. Crankshaft has a snub nose taper that only mounts a v-belt pulley with no woodruff key, not suitable for front #46 Hydraulic Control drive. Basic block is the same but many bolt on's are different.
Wed, Nov 8, 2017 1:44 PM
oldbeek
That was the standard Delco starter in the 1950s prior to the enclosed MT40s. They work jest fine. Should have a rubber boot on the solenoid plunger.
Thu, Nov 9, 2017 11:43 AM
Reply to oldbeek:
Ok, I vaguely recall that version. The original starter for that engine would have been the early 40MT inertia drive type. Any lever type would have been an improvement.
Thu, Nov 9, 2017 2:03 PM
rogerjmartin
Other than the front crankshaft being different would the engine bolt in a 9UD6? Roger
Sun, Nov 12, 2017 5:28 AM
