Cat 30 manifolds and cylinder jug wanted
Showing 1 to 7 of 7 results
Breakrocks
Send a private message to Breakrocks
I'm trying to track down manifolds for my cat 30. I tried emailing catman but have had no response. Also need a cylinder jug.
Thu, Jan 8, 2026 6:24 PM
Breakrocks
I found a jug but no luck on the manifolds yet.
Sun, Jan 18, 2026 9:22 PM
Thank you received: 227
Worst case scenario, do as Diesel35 did on his Sixty - some ingenuity and pipe fittings make manifolds, at least till you find what you are looking for. Wasn't the fellow in the UK going to cast some new ones? - cts
Sun, Jan 18, 2026 11:15 PM
There is a new posting - https://acmoc.org/forum/for-salewanted/caterpillar-30-and-schramm-restoration
Might be of interest in your search for Thirty Manifolds - Good Luck. - cts
Sun, Jan 25, 2026 3:56 PM
Steve A
I have a 30 intake, will need some work but solid, located near lansing MI
Tue, Feb 3, 2026 1:17 AM
Cat-Iron posted on the above thread - might check it out, says there are Thirty Manifolds on the shelf. - cts
Tue, Feb 3, 2026 5:20 AM
Breakrocks
I sent Cat-iron a message last week but have not received a reply yet.
Fri, Feb 6, 2026 2:15 AM
Breakrocks
I'm still in search of some Cat 30 manifolds if anyone has a line on some.
Wed, Oct 14, 2026 12:39 AM
