Cat 212 grader
Cat 212 grader
Erie22
Send a private message to Erie22
Wanted information on ware I can get an oil cooler for a 212 grader
Tue, May 26, 2015 7:52 AM
Thank you received: 61
Unless you are bent on originality it is quite common to bypass the oil cooler by plugging the oil ports and removing the cooler bypass relief valve. In later models Cat eliminated the air cooled oil cooler completely as it was determined with better oils it was not needed.
Tue, May 26, 2015 8:35 AM
Jeff M.
I have one for a early one with the 3400 motor
Wed, May 27, 2015 9:34 AM
