Cat 12 grader
Cat 12 grader
Showing 1 to 6 of 6 results
Remuda
Send a private message to Remuda
I'm looking for parts for a flywheel engage lever or a replacement lever on a cat 12 grader 8T15407. Advice on a conversion kit to direct start would be appreciated.
 Thank you
Paul
Tue, Apr 20, 2021 9:41 PM
Thank you received: 52
You will need to bore and tap the flywheel housing for the starter. Use this template except the vertical pony flange to center is 10.3125" and the horizontal to center is 3.4825" for the 8T grader.
Factory hole would be 3-5/8" you can bore to 3-3/4" if you need some wiggle room.
  [attachment=62925]D6 Template Dimensions (4-16).jpg[/attachment]
Wed, Apr 21, 2021 9:24 AM
Remuda
Thank you,
Where can I find a starter or parts grader?
Paul
Wed, Apr 21, 2021 10:00 PM
Reply to Remuda:
Thank you,
Paul
Where are you located? Are you looking to run 12v or 24v?
Send me a PM when your ready for a starter.
Wed, Apr 21, 2021 11:08 PM
bboaz
Old Magnet, Is your layout for boring the flywheel housing above (10.3125 vertical and 3.4825 horizontal) the same for a 7T grader(7T2466 1947 Model, I think) with the 4600 motor? I am using the motor out of a 5R dozer in this grader since the one in it is locked up. Previous owner ran it out of oil on a hill and locked up the motor. Going to change the flywheel housing, oil pan, oil pump, flywheel, head, injection pump and injectors from the grader motor, but since I will have the flywheel housing off it would be a good time to set it on the mill and bore it for a starter. Thanks bboaz
Tue, May 4, 2021 8:12 AM
Reply to bboaz:
Sorry, can't answer that. I have not dealt with a 7T grader conversion.
Tue, May 4, 2021 9:30 AM
bboaz
Tue, May 4, 2021 10:17 AM
