carb for 1957 starting engine D-7
carole walker
Send a private message to carole walker
Carb found in friend's shop poor condition. We think it is for pony engine 1957 D-7. Free to any member who can use it
It has manifold but end is broken.
Gene Walker
Mon, Jun 26, 2017 6:42 AM
seyser
Thank you received: 60
Does anyone know if this would be the same as used on a 1941 D7 7m? I just started digging into mine and the throttle shaft appears to be seized.
Believe the tag on mine is 7B4721
Jeremy
Mon, Jun 26, 2017 8:28 AM
Andrew
Reply to seyser:
Jeremy
I f the carby is off a 3T it will fit your 7M but a carb of a 17A wont fit your 7M.
I wonder where the seller got that date from.
A photo would be great.
Mon, Jun 26, 2017 10:21 AM
mikekent1
Send a private message to mikekent1
Reply to Andrew:
you can free up stuck stuff by putting in water and bring to a rolling boil . it worked on a D2 carb
Mon, Jun 26, 2017 11:35 PM
seyser
Reply to mikekent1:
I might have to try that tonight. The linkage side is free and I was able to get the butterfly to move slightly but don't want to twist the shaft. It appears the butt end of the shaft is where its tight.
Tue, Jun 27, 2017 12:15 AM
mikekent1
Reply to seyser:
use transmission fluid works wonders
Wed, Jun 28, 2017 8:13 PM
