Cable blade system for D4
Showing 1 to 7 of 7 results
Dan1942D4
Send a private message to Dan1942D4
Hello, I'm restoring a 1942 7J D4 (old U.S. Navy machine) and am looking for the entire cable blade system, from winch to canopy, frame, blocks and blade.  Pretty much any location in North America will be OK. May consider individual parts of the system if need be.
Thanks for any info or advice.
Dan
Sat, Mar 18, 2023 4:20 AM
One in Ohio
https://www.facebook.com/marketplace/item/779849573466668/?ref=browse_tab&referral_code=marketplace_general&referral_story_type=general&tracking=%7B%22qid%22%3A%22-4454613838083738626%22%2C%22mf_story_key%22%3A%2236388807305276007%22%2C%22commerce_rank_obj%22%3A%22%7B%5C%22target_id%5C%22%3A36388807305276007%2C%5C%22target_type%5C%22%3A6%2C%5C%22primary_position%5C%22%3A2%2C%5C%22ranking_signature%5C%22%3A638297196055232512%2C%5C%22commerce_channel%5C%22%3A501%2C%5C%22value%5C%22%3A0.0015276997122641%2C%5C%22upsell_type%5C%22%3A129%2C%5C%22candidate_retrieval_source_map%5C%22%3A%7B%5C%226011334805611602%5C%22%3A801%2C%5C%226391341200899111%5C%22%3A801%2C%5C%229113674738674921%5C%22%3A3021%2C%5C%226719102244783220%5C%22%3A3501%2C%5C%224394232420700445%5C%22%3A701%2C%5C%226357640584268676%5C%22%3A701%7D%2C%5C%22grouping_info%5C%22%3Anull%7D%22%2C%22lightning_feed_qid%22%3A%22-4454621878276632353%22%2C%22lightning_feed_ranking_signature%22%3A%22638297196055232512%22%2C%22ftmd_400706%22%3A%22111112l%22%7D
Tue, Mar 28, 2023 7:47 PM
Dan1942D4
One in Ohio
Great, thanks for the heads up Rome K/G. I will check it out.
Wed, Mar 29, 2023 3:49 AM
D13
Send a private message to D13
Reply to Dan1942D4:
I have one also have 1943 d4 to go with it
Fri, Apr 14, 2023 3:26 AM
D13
Reply to D13:
Yeah the 1943 D4 serial number 7j9186sp
Fri, Apr 14, 2023 3:28 AM
D13
Reply to D13:
I guess I forgot to tell you I'm in Minnesota
Fri, Apr 14, 2023 3:29 AM
Dan1942D4
Thanks for your response. I'm interested in getting some details. My email address is [email protected] if you'd like to get in touch with me that way with your phone number I can give you a call.
Dan G.
Fri, Apr 14, 2023 7:38 AM
Reply to Dan1942D4:
Dan G.
Here's another
https://www.facebook.com/marketplace/item/252672900664070/?ref=browse_tab&referral_code=marketplace_general&referral_story_type=general&tracking=%7B%22qid%22%3A%22-4291688754904072076%22%2C%22mf_story_key%22%3A%2228332293799731842%22%2C%22commerce_rank_obj%22%3A%22%7B%5C%22target_id%5C%22%3A28332293799731842%2C%5C%22target_type%5C%22%3A6%2C%5C%22primary_position%5C%22%3A8%2C%5C%22ranking_signature%5C%22%3A6701503034624573440%2C%5C%22commerce_channel%5C%22%3A501%2C%5C%22value%5C%22%3A0.00021228960496094%2C%5C%22upsell_type%5C%22%3A100%2C%5C%22candidate_retrieval_source_map%5C%22%3A%7B%5C%229214959635212094%5C%22%3A3003%7D%2C%5C%22grouping_info%5C%22%3Anull%7D%22%2C%22lightning_feed_qid%22%3A%22-4291699131599213043%22%2C%22lightning_feed_ranking_signature%22%3A%226701503034624573440%22%2C%22ftmd_400706%22%3A%22111112l%22%7D
Tue, Apr 25, 2023 6:17 AM
