955h caterpillar turbocharger
Showing 1 to 10 of 17 results
hopy-dah
Send a private message to hopy-dah
I have a 955h track loader, serial# 60A4776 and I am looking for a turbo that will work on it. The old turbo is not repairable and I am having trouble finding one. The original OEM# is 8M0019. The turbo modle is 4A351. Does anyone no where I can find one or if a different one can be installed with an adapter plate.
Thanks for any help you can give me.
Sat, Sep 7, 2013 3:28 AM
invisabledog
Send a private message to invisabledog
Run a part number search on Machinery Trader. There are two places that have one.
Sat, Sep 7, 2013 4:19 PM
Thank you received: 19
Reply to invisabledog:
Might try here....http://www.turbosupply.net/bwcartridge.html
Don't know anything about them.
The 8M0019 is a model 4A-351 Borg Warner/Schwitzer unit.
They list a cartridge for it but who knows on actual availability.
Sun, Sep 8, 2013 6:14 AM
hopy-dah
[quote="Old Magnet"]Might try here....http://www.turbosupply.net/bwcartridge.html
They list a cartridge for it but who knows on actual availability.[/quote]
The machinery trader site does not have a turbo, they will only reman the old one. The housing on mine is destroyed.
Does anyone know of a turbo off of a dillerent machine that could be adapted to the 955?
Thank You
Mon, Sep 9, 2013 10:42 PM
d9gdon
Reply to hopy-dah:
Thank You
That turbo was used on serial numbers 60A3222 to 60A4789. Try some of these guys who have dismantled 955Hs, a lot of times they won't list individual parts by numbers in Machinery Trader. I see a couple in that serial number range and I've dealt with Utah Track before:
http://www.machinerytrader.com/list/dismantledsearch.aspx?ETID=3&Manu=CATERPILLAR&Mdltxt=955H&mdlx=exact
Also, the way I read it in NPR is that this 8M0019 replaced the 7M7254 turbo from 60A1 to 60A3221. I would think that turbo would work also. Old Magnet can confirm if I'm right or wrong.
Tue, Sep 10, 2013 12:46 AM
hopy-dah
Reply to d9gdon:
[quote="d9gdon"]That turbo was used on serial numbers 60A3222 to 60A4789. Try some of these guys who have dismantled 955Hs, a lot of times they won't list individual parts by numbers in Machinery Trader. I see a couple in that serial number range and I've dealt with Utah Track before:
Also, the way I read it in NPR is that this 8M0019 replaced the 7M7254 turbo from 60A1 to 60A3221. I would think that turbo would work also. Old Magnet can confirm if I'm right or wrong.[/quote]
Thank you for the info, I will check the machinery trader again.
Tue, Sep 10, 2013 10:48 PM
Reply to d9gdon:
7M7254 shows up as "Oil system G. Turbo Field Changeover"
The 60A turbo progression from my parts books shows
7M0166 60A1-up (not a complete s/n coverage)
9M7524 60A5000 to 60A8412
2S7363 60A8413 to 60A10610
2S3512 60A10611-up
Also shows a 8M0019 interchanges with a 7M0166
So, I'm thinking the 8M0019 is either shown in the 60A1-60A4999 series which I don't have complete parts book coverage for or the 8M0019 is already a substitute model.
As far as other fits I'd try moving up the s/n range and see if there is a unit available.
d9gdon
2S3512 60A10611-up
Yes, Old Magnet has it right. I looked at the info wrong in SIS and didn't catch the Field Installation.
It shows 7M7254 to be a Field Installation from 60A1-1899.
It does show 7M0166 to be used from 60A1-3221.
The 8M0019 shows to be the replacement turbo for the 7M0166 from 60A1-60A3221 and the 9M7524 from 60A3222-60A4789 in NPR.
Wed, Sep 11, 2013 12:40 AM
Reply to d9gdon:
Found a few more tid bits,
Yes, 7M0166 is good from 60A1 to 3221
8M0019 60A3222 to 4789
8M6823 60A4790 to 4813
9M7524 60A4814 up
Wed, Sep 11, 2013 12:47 AM
hopy-dah
9M7524 60A4814 up
[quote="Old Magnet"]Found a few more tid bits,
9M7524 60A4814 up[/quote]
Thank you very much for the info. At least I have some new numbers to work with and I hope that I can find one that will work.
Thanks again and I will keep you posted.
Thu, Sep 12, 2013 1:26 AM
martin55
Send a private message to martin55
Reply to hopy-dah:
Heres the guy I get turbo cores from
http://www.goldfarbinc.com/
They may have something.
Fri, Sep 13, 2013 9:52 AM
