944 Wheel loader tie rod end
crbearden
Send a private message to crbearden
Desperately need a tie rod end for my 944 wheel loader.  Left or right will work.  old part number is 2F8609 socket assembly
if you have one text or call crbearden @ 4056418547
Machine is a 944 serial 43A 4620.
Wed, Nov 22, 2023 10:08 AM
I was thinking check with a truck spring/suspension shop, they may be able to match one up. Maybe this guy, lol
https://www.youtube.com/shorts/CHJsIKtKMuU?feature=share
Thu, Nov 23, 2023 4:48 AM
crbearden
The tie rod end is listed as a socket in the parts manual.  It has the typical tapered stud that fits in the steering arm, Then the tie rod is threaded about 1in fine thread the the end is split and female threaded with 2 bolts that clamp it to the tie rod.  All truck ends are a threaded stud to go into a coupler.  There is no coupler on a 944.  Thanks for the reply.
Thu, Nov 23, 2023 9:41 PM
Reply to crbearden:
Oh ok.
Thu, Nov 23, 2023 10:06 PM
| Kingaroy, Queensland
