6 cyl injection pump
Holt2ton
Send a private message to Holt2ton
Don't know history on pump. Been sitting inside. Make offer
Tue, Dec 31, 2013 12:38 AM
BillWalter
Would that be off of a D337 engine like used in a DW 15, DW 20 or 21?? Bill
Tue, Dec 31, 2013 12:43 AM
Holt2ton
Reply to BillWalter:
I really dunno. I assume if you cross match the casting numbers you could find out. I have no way of finding out
Tue, Dec 31, 2013 2:32 AM
d9gdon
Reply to Holt2ton:
Can anybody make out the casting number and I'll try to look it up?
Tue, Dec 31, 2013 2:36 AM
chriscokid
Reply to d9gdon:
looks like 5M7865?
Tue, Dec 31, 2013 3:33 AM
Reply to chriscokid:
looks like 5M7865?
also has a D343 engine look about it as they also used the flat back mounting, this pump has the same D343 looking turbo return elbow. I cannot recall where the D337F turbo return went.
Elbow part no I have from a D343 engine in a 630 Tractor book is 2M6643.
I think on the D337F the turbo return was in different location.
From the pix provided, Bill has made a good call as both pumps are very similar--in fact I call the D337F the Father of the D343 as there are many similarities/carryovers. Some of these started in the Early Series D337, the trend to rear timing gear drives, angled exhaust manifold faces and so on.
Tue, Dec 31, 2013 8:42 AM
