#44 Hyd Pump input shaft seal replacement?
randy merrick
Send a private message to randy merrick
Trying to replace the seals around the drive shaft on my #44 hyd pump ser #6W12536. I have the unit off and have also pulled the pump from the unit. I have a copy of the page from a parts book showing the parts detail so at least I can see what they look like
My question is can the "Retainer" part #4F3964, which appears to hold the seal, be removed by just taking out the 4 cap screws? Or do I have to dismantle the whole pump?
I have tapped on it with a chisel to try and get it free and then I tapped a little harder. It does not seem to have budged at all. The pump seems fine so I would rather not take it all to pieces if I do not have to.
Thanks for any advice, randy
Sun, Jun 16, 2013 9:40 PM
josh
Thank you received: 14
The retainer can be pretty snug in there, but will come out without taking the rest apart, may take some soaking and lots of tapping with a brass drift or plastic mallet, but should come free, just don't bust it, you might make a small hook type, slide hammer puller and hook the edge near the shaft, once it is a little loose.
Sun, Jun 16, 2013 10:18 PM
randy merrick
Reply to josh:
Thanks for that detail. Did not want to keep trying only to find out that that was something holding it from behind.
Will persevere.
randy
Sun, Jun 16, 2013 10:36 PM
randy merrick
Reply to randy merrick:
Will persevere.
randy
oops I just realized I was on the for sale section and not discussion when I post this, sorry, randy
Sun, Jun 16, 2013 10:41 PM
