27 cat 60
marty-shefts-4415
Send a private message to marty-shefts-4415
I have been corrected and it is not a pressure plate but a plate assy that the clutch plates are on ither side part #2318-a. thanks will wingo.
Thu, Apr 10, 2025 6:56 PM
Thank you received: 164
Look on E-bay - several Stewart-Warner Vacaum tanks listed -
Mon, Apr 21, 2025 11:51 PM
clayton
Thank you received: 21
What’s the part number on the clutch pressure plate?
Tue, Apr 22, 2025 12:17 AM
marty-shefts-4415
Reply to clayton:
it is 2318-a plate assembly.
Sat, Apr 26, 2025 11:37 PM
willwingo
Thank you received: 8
There is nothing on a Caterpillar Sixty that is classified as a "pressure plate" in the flywheel clutch.
The "plate assembly", part # 2318-A is the heavy steel center section. There are 2 plates that clamp onto the plate assembly when the clutch is engaged, that are lined (Disc part # 475-D-1 the lining). There are several part #'s for the "plate assembly" depending on the serial # of the tractor.
You need to look at the "Sixty Tractor Parts Catalog" form UE5451 to figure out what you need.
Sun, Apr 27, 2025 2:53 PM
marty-shefts-4415
Reply to willwingo:
you are right the plate assy is what I need. thanks.
Sun, May 4, 2025 11:02 PM
