2 D2's in Central NY on FB - Not Mine
rhartwick
Send a private message to rhartwick
I saw these two listings for D2's on FB:
https://www.facebook.com/marketplace/item/204334844914697
https://www.facebook.com/marketplace/item/486509539096222
I was tempted with the winch one, but decided against it as I have enough projects already.  Just wanted to pass these on in case anyone is looking.
Sun, Jul 4, 2021 7:26 PM
Mike Meyer
Thank you received: 6
Thanks for sharing the links, I know "Neil" has been looking for decent D2 undercarriage for years and these tractors are right in his back yard.
Mon, Jul 5, 2021 2:56 AM
Thank you received: 77
Reply to Mike Meyer:
Problem is Mike they're not long track frames. At this stage, that's the only criterion for me, which means the serial # has to be 5U13273 and up. That said, there's a fellow in the JD club here that's looking for a D2. That one in Dolgeville looks right up his alley. If I didn't already have a unit with a blade, I'd get that toolbar tractor because I want to do ag work and that looks like just the ticket : )
Speaking of which, I took my 5U to my buddy's place and starting clearing the overgrowth from his 5 acres. First time I've done any real work with it, and I'm pleased to say the tractor (and the trailer I took it there on) performed flawlessly. I can see that it's due for a cylinder head retorquing, the gas line from the tank to the valve by the pinion control is leaking and needs replaced, and I really need to get the hydraulic control guard refitted. __PRESENT
Mon, Jul 5, 2021 5:30 AM
Mike Meyer
Never heard of a cut and tuck Neil, smart fella like you with a gas axe would have those old short frames sliced and diced to create a pair of nice new extended track frames in a hour or 2, much easier than making them from scratch! LOL
Mon, Jul 5, 2021 11:41 AM
