1954 D6 Traxcavtor Pony Motor
Paradise Acres
Send a private message to Paradise Acres
Searching for piston rings and connecting rod bearings for my pony rebuild. Any sources out there that anyone knows of.
Thought I had everything I needed and the supplier canceled my order at the last minute.
Any suggestions would be greatly appreciated.
Sun, Jul 9, 2023 10:36 PM
gemdozer
Online
Thank you received: 12
What rod bearing size and ring .
Mon, Jul 10, 2023 3:24 AM
Busso20
Thank you received: 9
Reply to gemdozer:
JP pistons in South Australia make pistons and rings definitely for the D2/4, you could dig thru there web or contact them, with exchange rate should be reasonable and new parts.
Mon, Jul 10, 2023 6:52 AM
Thank you received: 24
Reply to Busso20:
The pony should be the same as any Cat D 318 engine.
Mon, Jul 10, 2023 7:04 AM
Paradise Acres
Reply to gemdozer:
Connecting rod bearings need to be .030 under and piston rings are .020 under.
Thu, Jul 13, 2023 7:42 AM
Price Tractor Pull
Price Tractor Pull
