1951 7u d4
Showing 1 to 6 of 6 results
Walter
Send a private message to Walter
wanted radiator cap and screw on cap for front mounted hydraulic tank. thanks for any help. walter
Fri, Oct 18, 2019 5:11 PM
Thank you received: 62
😉 Caterpillar is still in business unlike all the other dozer makers of the time of your machine. I would suspect you could buy them new. And if not check places like Florene Tractor or other places in the parts sources that are listed here on this forum.
The list is a bit hid at least for old dirt farmer like me.Go to the menu page and go to the bottom and click on sources.
Fri, Oct 18, 2019 11:21 PM
BigAgCat
Send a private message to BigAgCat
Reply to Ray54:
Yeah, you can buy a new cap for the fuel tank, I would imagine radiator caps and hydraulic caps would be just as available.
Cat D6 5R
Sat, Oct 19, 2019 12:37 AM
Reply to BigAgCat:
The cap, 1L7583 [new number] is available from Cat for $142.34
Sat, Oct 19, 2019 4:34 AM
Reply to BigAgCat:
if you have the part numbers i can check my online Cat parts store and see if they are avaialable
Sat, Oct 19, 2019 4:39 AM
Walter
Reply to dpendzic:
don't have any numbers. just moved all books are packed in storage. have bought new radiator cap before but don't know about hydraulic cap. if anyone has number that would be great. thanks walter
Sun, Oct 20, 2019 7:27 AM
Reply to Walter:
Cap # is 4F8842 changes to 6K6977 $42.06 from Cat, gasket # is 4F8843 $3.84 from Cat
Tue, Oct 22, 2019 12:04 AM
