1948 d6-9u
sawatzky1
Send a private message to sawatzky1
From the High Plains Journal classified November 2
1948 D69U258 12' hydruilic blade run good need pony motor. $8000.00
Cell 719-569-1715
Wed, Nov 4, 2015 4:53 AM
old-iron-habit
[quote="sawatzky1"]From the High Plains Journal classified November 2
Cell 719-569-1715[/quote]
Seems plenty spendy. Let us know if it sells.
Wed, Nov 4, 2015 8:08 AM
sawatzky1
Reply to old-iron-habit:
Location is south of Pueblo Colorado. Unit was purchsed to build a ranch road and the project is done. Previous owner used it for the same reason. Hydrulics work fine. The pony motor has a cracked block and so the owner pull starts it. no pictures yet but the price is negociable.
Fri, Nov 6, 2015 5:38 AM
Willowhic
Send a private message to Willowhic
Reply to sawatzky1:
$ounds way too pricey for a machine with a bad pony that requires pull-starting...unless the UC is pristine, a more reasonable figure would be a couple/few thousand less.
1988 JCB 1400B backhoe
1966 Cat D9 cable dozer
1966 Cat 980 wheel loader
1967 Galion 140 grader
1963 Cat D7E hydraulic dozer 47A886
196? Cat 112 grader 3U3308 (engine: 3U243)
Fri, Nov 6, 2015 6:15 AM
