1935 Cat 22 on Craigslist in Tennessee
caver
Send a private message to caver
I stumbled across this on a Tennessee CL and have no connection to the seller.
https://jacksontn.craigslist.org/clt/d/1935-caterpillar-model-22/6754865261.html
Side note: I have found some old Cat dozers on Facebook Marketplace which depending on your area might be better than CL.
Tue, Dec 11, 2018 12:19 AM
STEPHEN
Ok, so I was in the neighborhood & took a few pics for you.
Fri, Dec 14, 2018 11:53 PM
STEPHEN
[quote="Garlic Pete"]Nifty freeze crack repair there. I always like stuff like that. Funny that tractor seems to be either complete surface rust or pretty good, chalky yellow. You don't often see a mix of patina like that.
Looks like a pretty nice tractor that would be a good starting point to get running.
Pete.[/quote]
Needs a better set of tracks and the radiator core is fan rubbed . No radiator cap. The CT4 mag has fresh paint & was reported by some previous owner to be worked on. Similarly the head head has been painted also a new valve cover gasket. Engine is stuck with no spark plugs installed.The rear cylinder block is crack repaired adjacent to the firewall. The owner seems to be a reasonable guy. I gave him the site address here. I didn't check the steering, brakes, or shifter.
Sat, Dec 15, 2018 3:55 AM
