Did the seat happen to have a gasket on it?
Then did you adjust the float level?
Is there any rust or crud that seems to be in the float bowl when you take it off?
[quote="drujinin"]Did the seat happen to have a gasket on it?
Is there any rust or crud that seems to be in the float bowl when you take it off?[/quote]
no gasket and yes there was crud between the fuel inlet and needle so i flushed and dipped the upper cover. float level was good and moved freely. The fuel line is gravity feed is there a pressure limit on the inlet?
Have you removed the pony gas tank, and cleaned it thoroughly? If not, you will be fighting the float problem forever.
