Yet another pony to elec question
LJMACKS
Send a private message to LJMACKS
Have a D7E 48A 6092. I am considering installing a 24v starter. Question: Will a 40 or 42M work or do I need a 50M ? 11T or 12 T ? Did Cat ever make a retrofit kit to plug the oil lines and water manifolds or do we just fabricate blanks?
Thu, Mar 28, 2013 8:36 AM
I'd recommend the 50MT starter, which was also used on the later models. The 12T pinion matches original pony pinion.
I only know of individual block off plates, don't think they ever offered a kit. Most folks make their own.
Thu, Mar 28, 2013 9:44 AM
johnstone
Send a private message to johnstone
Hi LJ,
Ran across this on Ebay...might want to check it out...http://www.ebay.com/itm/NEW-50MT-PONY-MOTOR-REPLACEMENT-STARTER-24VOLT-24V-CATERPILLAR-D7-D8-D9-/110922514286?hash=item19d37f3f6e&vxp=mtr
Johnstone
1954 D47U, 1957 D69U, 1987 JD 950
Fri, Mar 29, 2013 4:40 AM
LJMACKS
Reply to johnstone:
Hi LJ,
Johnstone
Thanks all, very helpful!, Bill A. New Jersey
Fri, Mar 29, 2013 7:33 AM
