yardage for CAT 740 dump box
Showing 1 to 6 of 6 results
Delta Dirt
Send a private message to Delta Dirt
Anybody know the cu. yardage for a CAT 740 dump box???
We've got a contractor running several here close by on a mainline Mississippi River Levee berm project. Big piece of equipment----------but really look top heavy and wobbly moving across rough terrain and soft spots in the fill area. (been a wet year)
[attachment=25060]Cat dump truck at Levee1.JPG[/attachment]
Delta Dirt
Delta Dirt
Avon, Ms 38723
D2 5U and other scrap iron
Mon, Sep 15, 2014 11:32 PM
22.8 yds struck, 30 yds heaped.
Mon, Sep 15, 2014 11:50 PM
truckun95
Send a private message to truckun95
They are very nice trucks top speed loaded about 36mph, and weight distribution loaded is 33% to each axle. Major issue is the trucks while loaded dumping their box on an unstabile surface with a narrow wheel base. They also make theses trucks with an ejector to evenly push material out of box. Often in my area contractors use the trucks with excavator or wheel tractor scrapers (dual engine) and push dozers depends on job size, distances, haul roads, and conditions.
Tue, Sep 16, 2014 6:06 AM
Delta Dirt
Reply to truckun95:
Thanks Magnet---------you are always "Johnny on the spot"!!!!.
They definitely qualify as nice dump trucks-------I had carried my soon to be 5 yr old grandson up to watch them work. He said they were "cool"---------and he is big into dump trucks and dirt piles right now!!!!!!LOL
Reckon CAT passed the test once again.
Delta Dirt
Delta Dirt
Avon, Ms 38723
Tue, Sep 16, 2014 8:54 AM
Reply to Delta Dirt:
Delta Dirt
Seems the capacity is a little more than I stated. Not sure where I grabbed the first numbers but here is a set of specifications.....
http://xml.catmms.com/servlet/ImageServlet?imageId=C505993
Tue, Sep 16, 2014 9:07 AM
gauntjoh
Librarian
I believe the designation 740 means a 40 tonne capacity. These machines are made in Peterlee in the UK, formerly DJB engineering.
Tue, Sep 16, 2014 12:32 PM
mrsmackpaul
Delta Dirt
[quote="Delta Dirt"]Thanks Magnet---------you are always "Johnny on the spot"!!!!.
Delta Dirt[/quote]
yes mate if grows up to be like his granddad he wont grow out of it 😖mile:
Paul
Tue, Sep 16, 2014 2:20 PM
