WWII Athey Munitions / Fuel Carriage Model
Showing 1 to 10 of 18 results
Aphonopelma
Send a private message to Aphonopelma
Hi All,
I decided I should get my Athey carriage modeled up before it leaves. Good way to document how it was built and the models can be used to RP (rapid prototype) a scale model at a later date. I've roughed out the frame weldment. I've used SolidWorks for @20 years now. This was 8 hrs of effort.
[attachment=26559]ATHEY FRAME ASY, BACK ISO.jpg[/attachment][attachment=26558]ATHEY FRAME ASY, FRONT ISO.jpg[/attachment]
I'll post more as I get the components finished.
Scott
1975 951C
Thu, Dec 18, 2014 8:55 AM
D6c10K
Send a private message to D6c10K
Looks good....Solidworks sure is nice to make models with isn't it?.....Just upgraded my seat of SW to 2014 version. (From 200😎. Can't afford to keep the maintenance up every year. I started with 2001 but you've probably put in a lot more hours on it than I have. Prior to that I used Pro/E for several years. (Mold work mostly) Lately I've been getting a few more hours in doing some cast urethane molds.
Next project is to design some battery box covers for my D6.....
Pet peeve....
Does it bug you on Solidworks that the Top Plane is oriented to the Tridad "Y" axis instead of "Z"? Drives the machinist in me absolutely NUTS...
Fri, Dec 19, 2014 6:38 AM
Aphonopelma
Reply to D6c10K:
Pet peeve....
I have all my settings setup custom, reset the planes, custom templates that tie into an MRP system if needed. I didn't even know that issue still existed with the default planes. I'm still on SW2012, saw no need to dump more money into bloated code. I'll have to upgrade probably around 2016 to keep up with the latest OS.
[attachment=26574]ATHEY CARRIAGE, BACK ISO, REV 2.jpg[/attachment][attachment=26573]ATHEY CARRIAGE, FRONT ISO, REV 2.jpg[/attachment]
Scott
1975 951C
Fri, Dec 19, 2014 11:00 AM
D6c10K
Reply to Aphonopelma:
Yea, you can reset the view orientation but it doesn't display the plane names for RH Plane correctly (turned 90°) I needed to upgrade partly because my hardware was so old.
Just trying to get used to 2014 ver....lots of changes, not all for the better at first glance, but I'll get used to it.
Not familiar with the carriage you've modeled.....is that something you're going to try and build?
Must be this one:
https://www.youtube.com/watch?v=Cx2QyDXEdmc
Fri, Dec 19, 2014 11:17 AM
Aphonopelma
Reply to D6c10K:
Must be this one:
Just documenting what I will be selling off. I can't be completely correct on the castings without dis-assembly which I won't be doing. Otherwise I could build a new carriage and fudge the unknowns.
Scott
1975 951C
Fri, Dec 19, 2014 11:50 AM
Peter C
Send a private message to Peter C
[quote="Garlic Pete"]
At the end of the three weeks, I did end up with a reasonable, two view, two dimension stick figure outline of two disks with a cylinder connecting them. I was pretty impressed, and I still think I have that program somewhere here in my office on an 8" floppy disk.
I'm glad you posting this here, it will be interesting to follow your progress.
Pete.[/quote]
Well, Pete, if you ever want to run the program again you might be able run it on my Atari 800 computer. And you can check your design with my Post Versalog slide rule!
Never can tell when you might need these things again.
Pete
Fri, Dec 19, 2014 9:35 PM
cojhl2
Reply to Peter C:
Pete.[/quote]
Pete
GP's discussion reminds me years ago to satisfy a Customer requirement I was trying to run a 360/25 running in mod/20 emulation which in turn was running 1440 emulation executing a Cobol to Autocoder translator to compile a Customer written Cobol program.
I would set this thing loose in the evening only to return the next morning with the message "Syntax error". Nothing else.
We finally dropped the project as not worth it.
Fri, Dec 19, 2014 10:07 PM
3J1Bill
Reply to cojhl2:
For the Grandson.
Fri, Dec 19, 2014 11:44 PM
old-iron-habit
Reply to 3J1Bill:
For the Grandson.
That is way cool. I'd love to have one for my grandson. Good job!!!!!
Sat, Dec 20, 2014 12:57 AM
mrsmackpaul
Reply to old-iron-habit:
got to agree that would have to be one happy grand son
Paul
Sat, Dec 20, 2014 2:36 AM
cojhl2
Reply to mrsmackpaul:
Paul
Grandson?? I'd like to have one for myself could use it for an irrigation trailer behind the SUV!!
Well, I guess the grandson could use it when he(they) visit!
Sat, Dec 20, 2014 3:20 AM
