WW2 color question
WW2 color question
Showing 1 to 10 of 18 results
Mike Meyer
I'm working on saving a WW2 built D4 2T right now and in some spots can see the olive drab green color under the flakey Highway Yellow but today when I pulled the injector pump off I can't see any drab green paint on the back side, just a light tan color, so that got me wondering if any of the WW2 Cats were painted a tan color for service in the deserts, or is that tan color just the original primer coat I'm seeing?
Mike
Sun, Apr 10, 2016 5:03 PM
Uncle Rich
Send a private message to Uncle Rich
That tan color seems to be a primer or interior color I have found inside the engines. I find it everywhere I have been on my 1952 D2
Sun, Apr 10, 2016 8:16 PM
ag-mike
Reply to Uncle Rich:
yes to this, i think its zinc chromate or looks like it.
Sun, Apr 10, 2016 9:39 PM
jbernd56
Reply to ag-mike:
I am working on steering clutches in a 43 2T and after washing, that same color is inside clutch compartment also.
Mon, Apr 11, 2016 7:38 AM
Mike Meyer
Reply to jbernd56:
OK thanks everyone, sounds like primer then.
Mike
Mon, Apr 11, 2016 9:17 AM
Andrew
Reply to Mike Meyer:
Mike
What color ya guna paint it Mike
Mon, Apr 11, 2016 11:09 AM
Reply to Andrew:
Hi Mike,
from previous discussions here it seems all wartime production was the olive drab as the majority of machines went to the war effort--special paper work and authority was needed to get a private Cat at that time--usually for food production purposes for example--I stand to be corrected.
I believe it should be olive drab but without Military insignia applied.
The tan is the sealer coating paint used to seal any porosity and also the casting sand onto/into the castings and it is applied before machining takes place.
Mon, Apr 11, 2016 1:11 PM
Andrew
Reply to edb:
Hi Mike,
Thanks Edd.
I sort of meant what shade of olive drab as there seem to be a lot of different shades and some restos are a bit glossy and dont look quite right.
Andrew.K.
Mon, Apr 11, 2016 2:48 PM
Mike Meyer
Reply to Andrew:
Good question Andrew, do you have a suggestion because I reckon there are probably 100 different shades of drab olive green aren't there so which ever one I chose I'm sure will be wrong in the eyes of some experts but it will be lusterless and as close to the odd patches of old green paint I can still find on the old girl, the engine block was cast on June 22nd 1944, the serial number is D4 2T4146SP and she is getting the full McCoy recon with new liners, rings, head recon, new tinwork, rebuilt final drives and undercarriage, pilot motor and hydraulic pump, not sure about the gearbox and clutches yet though suspect I'll take the tranny top off while the tinwork and tank is off.
Mike
Mon, Apr 11, 2016 5:27 PM
D6c10K
Send a private message to D6c10K
Mike
I would think that would be correct....all the WWII vehicles I've seen had the flat OD. Don't think anyone will fault you on that paint.
Mon, Apr 11, 2016 8:29 PM
catsilver
Mike
The original military machines were drab olive green, but others supplied on lease/lend and sometimes for military use were supplied in a deep green gloss somewhere between forest green and the peace time green gloss used by the British army.
Mon, Apr 11, 2016 8:30 PM
