Would you try to fix this block?
Showing 1 to 10 of 14 results
Joel59
Send a private message to Joel59
Caterpillar 3304 block casting number 2P940. Do you think it’s a good idea to have it fixed or is it playing with fire??[attachment=49592]BC850ED8-1749-4A2A-9475-3DE9EA7A0A8B.jpg[/attachment][attachment=49593]9C780C91-C325-43B0-9CDA-64A7489A2BF3.jpg[/attachment][attachment=49594]56B30E40-DE3B-4D95-9CD5-236E6216D689.jpg[/attachment]
Sat, Jun 30, 2018 3:32 AM
"Might as well load up another nitro barrel"
[attachment=49595]John Wayne.jpg[/attachment]
Sat, Jun 30, 2018 4:01 AM
Joel59
I take it that means it’s a junker!
Sat, Jun 30, 2018 5:34 AM
Thank you received: 77
Reply to Joel59:
Joel, talk to a few reputable shops and see what they say - someone that does this day in and day out - and compare to the cost of a replacement block
Sat, Jun 30, 2018 5:53 AM
Reply to Joel59:
If it was mine, no go.
Sat, Jun 30, 2018 8:38 AM
restore49
Considering both sides of the crack are visible - a skilled welder could Braze it. Bob
Sat, Jun 30, 2018 8:47 AM
mog5858
Reply to restore49:
well need more info. with a newer block like that dose that the motor has to make money or is it just out of a toy. as funny as it sounds some of us are in to the problem solving / fixing more than running of the equipment. so you could research how to fix a crack block and then have a go but if it's a money maker than get a new one so you have reliable motor what's it out of 627? all depends how you value your time and what tools you have available.
Sat, Jun 30, 2018 9:40 PM
WA7OPY
Send a private message to WA7OPY
Reply to mog5858:
Its junk, any repair will distort the rest of the machine work,by the time you restore the liner bore and deck the head surface the cost is more than the block is worth. It will also be hard to stop the crack from running. A repair shop would not stand behind the repair so you have nothing....WA7OPY
Sat, Jun 30, 2018 10:13 PM
Reply to WA7OPY:
The 3304 blocks are pretty plentiful and not worth messing with extensive repairs.
Sat, Jun 30, 2018 10:21 PM
Reply to mog5858:
955L, D4E size engine.
Sat, Jun 30, 2018 10:57 PM
nomorejohndeere
Send a private message to nomorejohndeere
New if your going to keep it and not want that fix to linger in your head when the next $$$$ repair comes along.
Sun, Jul 1, 2018 1:33 AM
