Would anybody have the current cat pn for D2 Glow plugs?
csx4916
Send a private message to csx4916
I was curious as I do not have a service manual but how would one go about testing glow plugs to determine if they are working?
Thank you
Tue, Mar 21, 2023 3:58 AM
3H2033
https://youtu.be/ZSZ3-Jomi8k
Tue, Mar 21, 2023 4:21 AM
csx4916
3H2033
Thank you for the current 3H2033 part number.
Would checking of the glow plug be just a current draw measurement and what might be the expected range if current measurement is the way to test?
Thank you
Tue, Mar 21, 2023 4:23 AM
Reply to csx4916:
Thank you
I believe it's 4-6 amps per plug. About 5 amps.
Tue, Mar 21, 2023 4:27 AM
Thank you received: 54
you do a resistance test so set for ohms 2k range setting is just fine. they should all be fairly even with each other and the reading will change with temp/time
you can also run power to them and use a clamp meter to read the current draw. same thing they should be fairly even.
Tue, Mar 21, 2023 3:52 PM
