Winter Starting D7-17a
Showing 1 to 10 of 11 results
955H
Send a private message to 955H
One hurdle at a time: Im converting my D7 to direct start, but what happens for cold starting? Before I had the pup to warmup the engine prior to starting.
I didnt see anywhere that i could put in a circulating heater? i could put 3 or 4 magnetic block heaters on it but i dont know if thats enough at 5 or 10 degrees. i prefer to do my heavy work in the winter at anywhere down to about 0 degs. The 955h has a block heater and is really comfortable to operate at those temps and once warmedup i think its easier on them (never gets hot)..........any suggestions?
KEVIN JOHNSTON
955H, D7-17A, JD 540 SKIDDER W/JD BACKHOE ATTACHMENT AND LOTS OF COCKSHUTT TRACTORS
Sun, Nov 23, 2008 11:09 PM
Should be able to get a circulating heater loop from the bottom cover plate or plug on the thermostat housing and one of the flange connections for the pony motor water circulation once you remove it.
Sun, Nov 23, 2008 11:54 PM
955H
Oh, so tie-in to a plug below theromstats on housing (cant circulate through the rad) run heater hose and circulating heater and draw from the area where the pup tied in.
KEVIN JOHNSTON
Mon, Nov 24, 2008 12:26 AM
Reply to 955H:
Yes, you are correct. You would have to also tie in to one of the plugs in the housing above the thermostats to include the radiator in the loop.
So, you would have a total of three heater hose connections.....one low at one of the pony flanges and two uppers on a "Y" to connect above and below the thermostats.
The connection across the thermostats would amount to a small bypass but I don't believe it would have much if any effect on operation.
I don't see any other way to tie in a heater. Sometimes a heater is shown in the Generator Set installations but I don't have a manual to check and it is not shown in my D339 Industrial engine Service Manual. Any input appreciated😊
Mon, Nov 24, 2008 1:23 AM
d75
Send a private message to d75
have you considered putting in glow plugs to start in cold I converted a 14a to direct-electric I put combustion chambers from a 46a that accept glow plugs got them brand new from Regal now I can start the cat anytime I want no matter the temprature. even at 10 degrees the engine starts in a matter of seconds
Mon, Nov 24, 2008 2:04 AM
Reply to d75:
Cat's recommendation for glow plugs is only down to 50 deg. F. then ether aid is recommended or supplementary heat (block heater/manifold heater). I have started mine in the 40's no problem, no ether or heat but that's getting near the edge.
Mon, Nov 24, 2008 3:07 AM
OzDozer
OM - I'm not sure where you got your start temperature recommendations from, but it's not in line with what I know, have been told, and have read.
We start Cats here in Australia all the time with temperatures down to freezing, and sometimes a couple of degrees below .. with no ether .. and only a minute, or a minute and a half, of glow plug heating.
Here's the pretty-much-standard, Caterpillar starting temperature guide chart ..
I would, however, agree .. that glowplugs are probably less of a desirable addition to a tractor with a DE conversion .. in Alberta .. than a block heater would be, in that climate.
Mon, Nov 24, 2008 2:24 PM
razz
Send a private message to razz
Reply to OzDozer:
I started my D7e on friday morn 10 deeges one min on pre heat then start. I have been building gov,t waterways. they is about 3 inches of frost now year is about done. Razz
Mon, Nov 24, 2008 7:57 PM
Reply to razz:
Oz,
Unlike some I don't make this stuff up as I go.
Didn't say I agreed with it....just stated Cat's information.
Mon, Nov 24, 2008 11:58 PM
d75
Oz,
block heaters are a good idea but they are limited to how far your power cord will reach with glow plugs your cat becomes self contained, if your near a power source then a block heater is a good idea. I think either way works just as good just needs to be based on your needs.
Tue, Nov 25, 2008 12:23 AM
OzDozer
Reply to d75:
OM - The info you have scanned appears to be late 1940's information, and was obviously current at that time. The chart I scanned is from the early 955 OMI, dated 1955, and is no doubt, a revised offering from Cat on starting temperature guidelines.
There were regular design improvements to starter motors, batteries, and engines, in the intervening period, and this obviously led to Cat revising the starting temperature guidelines after a number of years.
Tue, Nov 25, 2008 8:50 AM
