Winch on 955H
Winch on 955H
Brandt
Send a private message to Brandt
I am winch ignorant, but would like a winch on my 955H (60A). Will a Hyster D6E winch be a simple install on my machine??
Thu, Jan 8, 2026 3:16 AM
Thank you received: 60
The correct winch for the 60A is a Hyster D4E. The D6 winch would be the wrong size.
Challenge would be to find one with all the controls for the 60A.
The advantage of the 60A is the range transmission has a neutral position that allows interruption of the winch drive to enable shifting of winch controls while the tractor is stationary.
Thu, Jan 8, 2026 7:06 PM
Thank you received: 79
basically a 955 of the era was a D4 with D6 undercarriage plus all the Traxcavator assembly added.
Fri, Jan 9, 2026 2:17 AM
