Winch cable question
Showing 1 to 10 of 14 results
Breadler
Working on a model 53 winch (D5C) and ready to replace the cable with 200’ of new 1/2”.
The existing cable was the typical nub/ferrule and pocket, however it was then threaded through a passage on the center of the drum, before winding. Is anyone else familiar with this? What I find odd, is that the passage is smaller than the ferrule, which means I can’t use a swaged ferrule and a swaged thimble eyelet at the working end. Wire clips will be a simple solution, just curious about that center passage.
D5C, D4-7U, D2-5U, D2-5J
Tue, Dec 24, 2024 7:33 AM
1972RedNeck
Send a private message to 1972RedNeck
You need the wedge that holds the cable in
Tue, Dec 24, 2024 7:36 AM
Breadler
I have the retaining pin which goes near the ferrule. Where is the wedge installed?
Tue, Dec 24, 2024 7:48 AM
Thank you received: 39
Reply to Breadler:
You need the proper size swedged ferrule...1.63" diameter/42mm and 2" long/51mm.
Tue, Dec 24, 2024 8:58 AM
Breadler
Yep, I believe it is the #B4, 1.63x2.00.
Still hoping to get insight on just running the ferrule in the pocket with the retaining cross pin, vs that plus feeding through the cross passage on the drum.
Tue, Dec 24, 2024 10:51 AM
jbernd56
Reply to Breadler:
feed the cable through the drum and let the end stick into the square pocket and pour lead around itl
Tue, Dec 24, 2024 10:19 PM
Reply to jbernd56:
None of the literature I have shows anything about attaching the cable. How close is the fit that is preventing you from threading the B4 ferrule?  Could be you can attache either way although I would tend to go for the original version.
Tue, Dec 24, 2024 11:08 PM
Breadler
Reply to Breadler:
The passage through the drum is probably 1/2” smaller, than the O.D. Of the ferrule.
The work around would be to use wire clips at the working end. Just not as “clean” as a swedged loop.
Or…use a two piece ferrule, like what is used to repair a choker.
Fri, Dec 27, 2024 6:43 AM
Thank you received: 47
Reply to Breadler:
as another suggested cast a lead slug around the cable end what actually holds it is the wraps of cable on the drum. the slug only stops it slipping till it grabs tight on the winch drum. the book will say the minimum number of wraps. never go below that.
many cables used to be terminated this way. often a ferrule was fitted over the cable and then that would be filled with lead.
a note with using cable clamps you want the pinch on the slack side of the loop not the line side so it is always straight and isnt deformed as that creates a stress point where it can fail.
Fri, Dec 27, 2024 9:41 PM
side-seat
Thank you received: 15
[quote]a note with using cable clamps you want the pinch on the slack side of the loop not the line side so it is always straight and isnt deformed as that creates a stress point where it can fail.[/quote]
Slang translation: "Never saddle a dead horse"
Sat, Dec 28, 2024 3:29 AM
Thank you received: 237
Never shoe a dead horse is what a trucker/gypo logger taught me.
Breadler: Found this old Hyster book for you; has some pertinent information in it I believe. JM
Sat, Dec 28, 2024 3:40 AM
