will my parts book work ?
Showing 1 to 9 of 9 results
kylerose
Send a private message to kylerose
Tomorrow i will be buying a D4 # 7U27391 , the parts book i have is for 7U27570 to 7U44307 . Will this parts book work for my machine or will there be quite a few differences? Ive been looking around and cant find one that covers the right serial number. I am also wondering if all the 7U service manuals are the same or if there is a certain one i should get for the machine ? Your answers are appreciated . Thanks
Kyle
Wed, Dec 10, 2014 11:16 AM
OzDozer
Kyle - Buy the correct part book that covers your S/N or you will likely end up with wrong parts when you order them. Engineering design changes were constant, and many design and part changes were subtle.
A D4 7U repair manual will be adequate for your tractor, however there will be slight changes to later issues.
If your tractor has an oil clutch, you will need the oil clutch repair supplement for the early manual.
Oil clutch repair info is in the later versions of the service manual.
Regards, Ron.
Wed, Dec 10, 2014 11:48 AM
kylerose
Reply to OzDozer:
Regards, Ron.
thanks ron ill keep looking for the right parts book , and ill check once i get it if it has an oil clutch
Wed, Dec 10, 2014 11:57 AM
Thank you received: 19
Reply to kylerose:
I find it useful to have both manuals 7U1-27569 and the 27570 to 44307. Allows you to see the upgrades and in some cases gives you more options for replacement parts.
Wed, Dec 10, 2014 1:55 PM
OzDozer
Kyle, I just did a check on the "new" oil clutch Service Bulletin for the D2 and D4, and the SB states the oil clutch can only be fitted from tractor S/N 7U29734.
The orginal D4 parts catalogs for 7U's are very difficult to acquire, they are in high demand. The early 7U parts catalog seems to be the hardest to find.
Regards, Ron.
Wed, Dec 10, 2014 4:18 PM
ag-mike
Reply to OzDozer:
Regards, Ron.
pm me ur address, i'll send u parts book for nothing. most are common to ebay, if u wait long enough u can get all them under 15.00 ea.
Wed, Dec 10, 2014 7:48 PM
Reply to ag-mike:
Kyle---i have the 7U1-7U27569 which is too old for my 7U-30755---i would be interested in a swap
Dan
Wed, Dec 10, 2014 9:21 PM
kylerose
Reply to dpendzic:
Dan
Dan , I'd like to keep the parts book that i already have because im also looking at buying a d4 that is covered by that book. There are currently a couple of those books for sale on ebay if that helps you out .
Wed, Dec 10, 2014 9:34 PM
Reply to kylerose:
Ok--Cool--looks like you are going to create a D4 fleet!!! :high5:
Thu, Dec 11, 2014 5:28 AM
kylerose
Reply to dpendzic:
would be nice to have a good runner and a parts machine , sure would help when something breaks . The guy that owns the other one i want for parts wants way to much money for it, but it may be worth it instead of trying to find and buy expensive new parts.
Thu, Dec 11, 2014 7:30 AM
Earlcoate Charity Open Day
