Will it fit
Will it fit
firekat
Send a private message to firekat
hello
Just wondering I have 1943 D8-8R but with a 2U nose with hydraulics and the Cframe is 11' 3" wide, wondering if a brush rake that is 11' 1" pin to pin (where the side arms mounts) fit or not fit?
Thanks for the input
firekat
Fri, Jul 18, 2008 11:39 AM
Doesn't seem like it would without modification.
If I'm getting the right picture the "C" frame would be for an angle blade that has the adjustable push arms come along the outside of the frame for attachment. This would put you well beyond your rake pin centers.
Fri, Jul 18, 2008 11:52 AM
firekat
sorry OM
I forgot it was late when I posted the question that the brush blade comes with sidearms that have plates welded to sit on the Cframe. hope you can see the picture. If not I will post more later today
firekat
Sat, Jul 19, 2008 1:04 AM
