will a 955h d330 t fit in a 922 loader
dblaz18
Send a private message to dblaz18
Hello again some more questions I found a 955h with a good motor but the machine is in rough shape so I was wondering if the 330 in it could be put in my 922 I know that the fuel rack would be different but is there anything else that would be a problem
Thanks dave
Tue, Aug 26, 2014 8:20 AM
rusted
Send a private message to rusted
[quote="dblaz18"]Hello again some more questions I found a 955h with a good motor but the machine is in rough shape so I was wondering if the 330 in it could be put in my 922 I know that the fuel rack would be different but is there anything else that would be a problem
Thanks dave[/quote]
It may be possible would be my guess (not sure of the trans cooler setup on the 955H), but if the 330T has a good crank it would probably be less hassle to use it to rebuild your current one.
Tue, Aug 26, 2014 2:59 PM
catsilver
Reply to rusted:
Thanks dave[/quote]
Check what engine you have in your 922 first, if my memory serves me right, the earlier ones at least were fitted with the 4" bore D320 engine,
Tue, Aug 26, 2014 5:32 PM
dblaz18
Reply to catsilver:
Mine is a d330
Tue, Aug 26, 2014 6:05 PM
