Will a 7U Pto unit fit on a 78A?
Rd6 plower
Send a private message to Rd6 plower
They look the same but wonder if tail shaft is the same?
Mon, Feb 4, 2019 3:27 AM
My understanding is that all the D4 PTO's will interchange but I have not tried them all. Even though shaft part numbers are different between the 7U units and later 78A units it has to do with shaft changes within the gear box itself, otherwise length dimensions are the same and both use the same splined couplings. I do stand to be corrected, maybe you can verify.
Mon, Feb 4, 2019 5:29 AM
Thank you received: 288
JR: I have a couple of spare PTOs if you happen to burn yours up and need replacement.
Mon, Feb 4, 2019 5:42 AM
