WILL A #44 hyd.unit off a d4 fit a d2?
zep
Send a private message to zep
I need a front hyd. unit for my d2 and was wondering if one off a d4 woul work and fit.Thanks.Tim
Tue, Feb 5, 2013 10:05 AM
Probably some difference in brackets and drive shaft, but the units are the same. The same unit on a D2 actually puts out more GPM because of a tad higher rpm on the D2 than the D4.
6W and 7W are 37 gpm on a D4 (1400 rpm)
8W and 9W are 25 or 27 if on a D2 (1525 rpm)
Tue, Feb 5, 2013 10:44 AM
Thank you received: 35
Hi Tim,
below are the specs for the 44 Hyd Control Units from Form No12914-2, dated 9-56, titled :- Servicemen's Reference Book for Hydraulic Controls and Equipment.
Hope this helps.
I am not sure what mounting hardware---brackets, drive shaft, linkages and lines,hoses and etc--- may be different between the D4 and the D2 but the units with the correct size pump do fit.
Tue, Feb 5, 2013 10:46 AM
josh
Thank you received: 13
The basic #44 unit is the same and will fit. That being said, the GPM of the pump is usually quite a bit higher on the D4 pump, (different cartridge that is not directly interchangeable with a D2 cartridge) the input shaft is different, mounting brackets different, control levers different. So yes it can be done, if you can find or make the parts you need ,but you would be better off if you can find one from a D2.
Tue, Feb 5, 2013 11:03 AM
Inter674
Reply to josh:
looking at the D2 and D4 side by side....ditto above...there are a lot of differences with mounts etc. Perhaps swapping the guts (pump) is therefore the best way to go?
Tue, Feb 5, 2013 11:58 AM
