Why does the Mag rotor keep breaking
Showing 1 to 10 of 15 results
fraser05
Send a private message to fraser05
I have a D2 5U2620 I recently bought. We started the pony ran for about a minute and died. Would not restart. I bought it anyway. Come to find the rotor broke. I bought another at a salvage yard for 300$ ran for about 3 minutes died. Would not restart. Rotor broke again.... Does any one have an idea as to why? Backfireing? All the teeth are good on cam and mag. Thanks Kyle
Sat, Jun 3, 2017 5:16 AM
Thank you received: 63
Not sure if this applies to the rotor, but mag shafts breaking can be attributed to a loose pony flywheel and/or worn pony crank bearings I've heard.
Is your flywheel tight on the crankshaft, and what's the play like in the crank? Don't want any more than about 015 radial and 025 axial to stay in spec. Lots of ponies run looser than than but it does risk the mag shaft.
300 for a rotor sounds very high. There are a couple of shops referenced on here that I'm sure can do much better than that price. By the way, update your profile (up there top of page on the right "My Profile" to update your city and state. There may be a member close by that can advise)
Sat, Jun 3, 2017 5:38 AM
fraser05
Thanks Neil.
It was a complete mag that I bought for 300. I talked to CAT they still offer a rotor that they have a few around for 110$ or so. I found another place in Chicago that wanted 140$ I think.
I've heard the same thing from the salvage guy I got the mag from. I thought it was hard to believe that you could get that much play in the cam (enough to break mag shaft or climb a tooth) without it being completely wore out. If I'm going to pull it apart to redo the bearing might as well rebuild the whole motor I suppose. Any idea what I'd be looking at for that?
Thanks for the Feed back.
Sat, Jun 3, 2017 11:36 AM
Reply to fraser05:
Thanks Neil.
Good timing as I've just done two lately. Rod shells are 30 from Cat per rod. Mains I can't remember but think are in the 50-100 range - need two of those, although for my two ponies, my machine shop picked up some generic oilite bushings and turned them to suit. Some folks make their own out of aluminum. It's basically a plain bushing with some oil channels cut into it, and a dowel hole that is drilled once the position of the bushing is established for crank axial float (010-015, 025 max). Head gaskets are cheap but you can also just reuse your existing ones. There are quite a few gaskets but gaskets, nuts and bolts from Cat are cheap. If you don't have a parts book for you serial # range, pick one up from ebay, in order to provide your parts man with the list of gasket parts. A carb kit runs about 50 from a few suppliers listed in the stickies up top. I had a mag reconditioned by Mainely Magnetos a couple of years ago for around 350 - it's like new.
Main thing in addition to all this is to thoroughly clean the coolant passages as they tend to clog up with sediment over time. First rod them out being sure to a) get the little holes at the bottom of the head and the corresponding hole in the block, and then the passage that crosses over the base of the block. That one is easiest to clean out with an old speedo cable. Alternatively you can pop out the frost plug on the underside and get in there that way.
Once you've done all that, it'll start on first or second pull, and idle sweetly. I install the carb idle jet/port/plug a little different to as-factory which for me greatly helped with the ability to idle. As-factory has it installed with the notch on the inner end more or less facing down, and with the parting line on the outer end vertical. Instead, I install it with the larger of the two notches on the inner end at bottom dead center so that the fuel can flow more easily. I found on mine that the throttle plate when closed obstructed the notch preventing mixture flow and thus no idle. As soon as I rotated that notch to BTDC, it idled like a couple of old Southern gentlemen sitting on the bench outside the store.
Sat, Jun 3, 2017 7:15 PM
captain k
Send a private message to captain k
Is the magneto distributor shaft and /or bushings worn enough for the rotor to strike the cap?
Sat, Jun 3, 2017 7:24 PM
Thank you received: 51
Reply to captain k:
Before you rebuild the entire tractor check that you have back lash (clearance) at the magneto drive gear. American Bosch parts diagrams refer to both the distributor rotor and magneto armature as rotors, the armature one being "rotor, magnet"
There is a AB Service Bulletin published about 1948 that states "due to accumulation of manufacturing tolerances" the total of some units may eliminate the backlash clearance at the gears. They suggest trying another magneto. If that doesn't cure it a thicker manifold gasket may be required to gain some clearance. In any event if there is pressure on the magneto drive gear or severe pulses due to loose flywheel or worn clearances you can expect rotor, magnet breakage.
Sat, Jun 3, 2017 10:21 PM
Cat no longer has any pistons for the pony engines [D2/D4]
Sat, Jun 3, 2017 11:40 PM
Found the service letter.....tough to read I know.
Sun, Jun 4, 2017 12:25 AM
fraser05
Old magnet.
Is this issue only with the Bosch mags or the wico also?
You would think cat could've made a new mag gear a shade smaller to allow for tolerance that could be easily replaced.
Sun, Jun 4, 2017 3:54 AM
Mike Meyer
Reply to fraser05:
Old magnet.
Try the easy fixes first before pulling the pilot motor off for a rebuild because $1,500 is what I keep hearing is what it costs, I've done three and if you do it yourself it can be done for under $1,500 provided your crankshaft isn't cracked and they often are, AND you can find all the bearings you need, the 2 main crank bearings are around $100- $115 each if you can find them in the sizes you need.
The top manifold gasket is about $25 and not hard to remove on a 5U though I haven't heard of anyone recently double stacking new manifold gaskets, double check your flywheel torque before trying any other repairs, from memory it is around 165 foot pounds and a loose flywheel from what I've read here are a fairly common cause for your problem as weird as it seems to non Mechanics like me.
Mike
Sun, Jun 4, 2017 4:17 AM
Reply to fraser05:
Old magnet.
[quote="fraser05"]Old magnet.
You would think cat could've made a new mag gear a shade smaller to allow for tolerance that could be easily replaced.[/quote]
I would expect the same gear backlash clearance requirement would apply to any magneto.
Sun, Jun 4, 2017 6:41 AM
