Why do you have to check the oil on Cat with the engine running?
Showing 1 to 10 of 12 results
gauntjoh
Librarian
Thank you received: 5
I guess the obvious answer is that Cat says that is how you should do it, but what is the reason?
I believe most other tractor manufacturers recommend checking the oil with the engine stopped.
Wouldn’t it just be a different mark on the dipstick.
Sun, Jan 5, 2020 3:19 PM
gvanhouten
Send a private message to gvanhouten
[quote="gauntjoh"]I guess the obvious answer is that Cat says that is how you should do it, but what is the reason?
I believe most other tractor manufacturers recommend checking the oil with the engine stopped.[/quote]
I believe because they want all the journals and top of the head filled and all surrounding areas lubricated... In addition to allow for the the warm oil to expand as to not overfill the oil... It is engineered for low idle and a warm engine.....
Sun, Jan 5, 2020 3:25 PM
MARCOTEN
Reply to gvanhouten:
So on engines for generators or engines in the arctic that should not be stopped you can check the oil level with engine running.
Sun, Jan 5, 2020 7:20 PM
bursitis
Reply to MARCOTEN:
probably as simple as "you don't have to pull the rope" just to check your oil. traditions and training employees are difficult to change
Sun, Jan 5, 2020 9:06 PM
Some have both engine running and engine stopped marks on the dipstick. The major determinant is that there is a shield to prevent oil splash on the dipstick with the engine running.
Sun, Jan 5, 2020 9:08 PM
"Them dipsticks! koo-gidget!!! could be a flaw in the slaw"
Sun, Jan 5, 2020 10:42 PM
bluox
Thank you received: 12
Wouldn’t it just be a different mark on the dipstick.[/quote]
So you don't have to shut the motor off and restart it as with a starting motor.
Bob
Mon, Jan 6, 2020 1:47 AM
janmeermans
Reply to bluox:
Bob
John,
Pretty much as others have said, when operating a pony started engine, shutting down mid-shift is a pain. If a motor is using oil, it is much simpler to check while running to see if more should be added. We would never shut them down over lunch but the oil "users" would be checked before going back to work. I think Cat was thinking ahead for the long shifts the machines would see in their life. As Marco says, sometimes they are never shut down at all for extended periods.
Just my opinion.
JanM
Mon, Jan 6, 2020 3:58 AM
gauntjoh
Librarian
Reply to janmeermans:
John,
Just my opinion.
JanM
I can understand the need to check oil level with the engine running but why not have two levels on the dipstick as cc says some engines have? Otherwise how do you know how much oil to put in eg after an oil change?
Mon, Jan 6, 2020 4:55 PM
8C 361
Thank you received: 10
Reply to gauntjoh:
Toby has a discussion on this topic in one of his latest Squatch253 videos comparing early J series engines with later. Has to do with the oil cooler and other areas being filled with oil.
Mon, Jan 6, 2020 8:03 PM
BigAgCat
Send a private message to BigAgCat
Reply to 8C 361:
Seems more logical to check the oil before starting.
Though, I think they suggest checking oil when the engine is running or just after the engine was running to make sure the oil level is still above the low mark with the engine running. The Full mark may not mean full while engine is running and it may be a good idea to have the oil level a little above the full mark on a cold engine.
Cat D6 5R
Tue, Jan 7, 2020 1:13 AM
