Which starter drive for 70D 3819 Motor Grader?
raklet
Send a private message to raklet
I am converting my 70D over to electric start. I ordered a 50MT starter with an SAE 3 145 housing and a 3-293A starter drive. The starter and the housing fit fine in the flywheel housing but the starter drive gear doesn't seem to mesh with the flywheel ring gear.
The flywheel housing was pre-machined by caterpillar to drop an electric starter in - just unbolt the cover plate and install the starter, but I have looked through all my parts and service manuals for information about starter configuration, but none is given. Does anyone else have material that addresses which starter drive gear to use?
Thanks.
Thu, Sep 30, 2010 7:39 AM
Those are the right part numbers. All those late graders and D6's, direct start or pony, used the same 7B6253 ring gear (112 tooth)
Are you sure you received the right drive RH helix, 11 or 12 tooth.
They also make a LH version.
Have you actually tried a fit up...what seems to be the problem?
Thu, Sep 30, 2010 8:51 AM
raklet
When I called the company, I specifically stated that I needed an SAE 3 145 and 3-293 or 3-293A. They sent me an SAE 3 180 and a LH drive. I called and made a stink. I received the new parts in the mail today and yes they are correct. The drive gear came in a box labeled 3-293A and when compared to the picture on Old Mag Cat the direction of the teeth go the same way.
I have fit it all up. When I energize the solenoid, it hums quite loudly but nothing else occurs. It doesn't even sound as if it is attempting to engage the starter drive with the ring gear.
I pulled the starter out and removed the drive gear to see how it fits up with the ring gear by itself. Holding the drive gear more or less in the center of the hole machined in the housing, the teeth of the drive gear overlap with the teeth on the ring gear by about 1". There is no way that any type of meshing will occur. The drive gear has to be pulled to one side of the hole in the housing to even get close to where the teeth mesh, but even then, holding the teeth against each other they don't seem like they are a good fit. The teeth don't appear to mesh (but I may not know what I am looking for either).
Thu, Sep 30, 2010 9:10 AM
Reply to raklet:
Somethings strange, haven't had that kind of problem with a factory hole.
Try this,
Put the drive back on the starter, take the solenoid housing off exposing the plunger. Mount the starter to the clutch housing and use the plunger to manually engage the drive if you can. If no go loosen the mounting bolts and see if it will now engage. Meshing of the gears has to come as a result of the helical motion which you don't have while manually engaging but should be close and they usually will mesh.
Thu, Sep 30, 2010 12:19 PM
ol Grump
Try this,
raklet,
I recently converted my " new" Cat 12E to direct start with an MT 50 starter. There's an adapter plate that goes between the starter and clutch housing that moves the starter outboard and to the rear a bit. Are you sure that one isn't needed for yours too?
Thu, Sep 30, 2010 7:57 PM
raklet
Reply to ol Grump:
raklet,
[quote="ol'_Grump"]raklet,
I recently converted my " new" Cat 12E to direct start with an MT 50 starter. There's an adapter plate that goes between the starter and clutch housing that moves the starter outboard and to the rear a bit. Are you sure that one isn't needed for yours too?[/quote]
Hah, no idea. That could be a possibility. Do you have a parts catalog for your machine? I would be curious to see what the part number of the clutch housing is so I can compare it to mine. Where did you get the adapter plate?
Thu, Sep 30, 2010 8:30 PM
raklet
Try this,
[quote="Old Magnet"]Somethings strange, haven't had that kind of problem with a factory hole.
Try this,
Put the drive back on the starter, take the solenoid housing off exposing the plunger. Mount the starter to the clutch housing and use the plunger to manually engage the drive if you can. If no go loosen the mounting bolts and see if it will now engage. Meshing of the gears has to come as a result of the helical motion which you don't have while manually engaging but should be close and they usually will mesh.[/quote]
That's a good idea. Will do that first thing this morning. Thanks.
Thu, Sep 30, 2010 8:31 PM
Reply to raklet:
Try this,
No adapter required. That didn't get used until the D333 & D330.
Thu, Sep 30, 2010 10:09 PM
raklet
Put it back in, engaged manually as suggested, reassembled and tried it again. Now it works! 👍 Must have been bound up funny the first time I put it on.
Thanks for all the help!
Thu, Sep 30, 2010 11:13 PM
