Which nozzles to use in CAT 922A D320T engine?
Nico Ensink
Send a private message to Nico Ensink
Hello you all,
I am about to replace the turbo non my CAT 922A S/N 59A1987 as it burns oil and replace the ferrules and head gasket as it occasionally leaks some water out of the head gasket, especially when it has run only short not reaching the operating temperature.
As it smokes I might also renew the injectionnozzles.
My book says Service group 5M2788 which has been changed into 3S6638 which contains a 2S4442 nozzle.
If i read other posts on this subject I find 2S4442 nozzles to be correct for non turboed engines where mine does have a turbo.
So I am confused now although I tend to go by the book and use the 3S6638 service group.
Who can bring some clarity here?
All reactions wellcome.
Nico
Tue, Jun 18, 2013 9:53 PM
Thank you received: 60
According to the parts book on the 933G (same D320T engine) the 3S6638 valve service group with 2S4442 nozzles is correct.
Tue, Jun 18, 2013 11:06 PM
farmks
Send a private message to farmks
D320 engine turbo or non turbo are the mostly the same. Pistons, heads, etc. are the same part numbers. The 933F is non turbo and 933G has turbo. I have both engines and am sure I have run the injectors in either engine without problems. The injector pump rack can be adjusted. You didn't say if smoke is from too much fuel or just burning oil. The turbo charged engine makes 10 extra horses which really help if your are pushing the machine hard.
John
Wed, Jun 19, 2013 10:00 AM
| Kingaroy, Queensland
