Where to find packing to fix shut off valve?
Showing 1 to 10 of 13 results
Arthropod
Send a private message to Arthropod
I was wondering what I can use to repair the diesel fuel shut off valve and where to find it? Does CAT still sell packing that could be used to repair those old valves?
Thanks.
Mon, Aug 31, 2009 10:39 PM
All the ones I have ever seen on the old CAT equipment have been a precision taper with brass on brass (at least that's what it looks like to me)
I see similar stopcock valves on propane supplies to furnaces etc. I would think best to just replace it if it won't shutoff tightly or leaks around the part that turns.
Tue, Sep 1, 2009 1:11 AM
Arthropod
ccjersey, thanks for the reply. Well, yes the valve is brass on brass, with the taper. But, I am talking about the top where the cap screws on that holds in the taper shaft. There is packing under this screw on cap and seals around the small shaft that has the square sticking out the top. There is some type of packing in the top part (under the cap) keeps fuel from seeping out. I have tightened mine before and stopped leaks, but this valve has worn out packing.
I went to a local hardware store during lunch and picked up two types of packing in the plumbing department. One teflon and one of graphite. I don't know if the teflon will be bothered by the diesel. I think I will try that first since the packing cord was larger diameter than the graphite cord.
Tue, Sep 1, 2009 2:06 AM
CarlsCAT
Send a private message to CarlsCAT
Reply to Arthropod:
I know that Teflon packing is quite good in packing glands for bronze propeller shafts for sailboats, and such...We also use teflon tape on all pipe fittings when installed...I would think that the Teflon packing would be the best...since it is not affected by fuels and other chemicals...
Respy, CarlsCAT
Tue, Sep 1, 2009 6:54 AM
jw45
Send a private message to jw45
Reply to CarlsCAT:
Respy, CarlsCAT
thier really shouldnt be any packing in that valve it should seal on that taper if you look close the taper and shaft should be one piece you can get a new one at the plumbing store the nut on top is suppose to apply pressure for sealing
Tue, Sep 1, 2009 8:42 AM
OldNuc
Send a private message to OldNuc
Reply to jw45:
There is a preformed packing in that valve between the hex cap and the plug. It is probably either cotton or asbestos impregnated with grease and graphite. finding one is going to be tough.
Tue, Sep 1, 2009 12:14 PM
Arthropod
Reply to OldNuc:
Thanks for all the replies. Every fuel shut off valve I have taken apart (several) has had some type of black graphite like packing cord under the cap. Maybe it was added because the valves were worn, but it really seems to be factory. Anyway, I figure it doesn't hurt to put something in there. I have wrapped the teflon cord inside the cavity and screwed the cap on. The valve still turns easily and to me it seems that it should stop the drip I was having. It won't see a lot of movement, so I think it will last a while.
Of course I couldn't finish the fuel line last night. I scrounged around my parts pile and found all the fittings I needed, cleaned them up. Soldered the ends on the copper line. Then I removed this old nipple from the tank so I could screw in a brass street elbow and found the threads are buggered up in the tank and someone had forced the nipple in. I didn't have a 1/2" pipe tap, so fuel work will need to continue after I get a tap. Always something with these old machines.
Tue, Sep 1, 2009 7:22 PM
CarlsCAT
Reply to OldNuc:
I've got a couple of the hex-cap fuel tank valves for my D2 on my workbench... I'll have to open one up and take a good look at it...As I recall, packing for the packing gland on boat stuffing boxes for propeller shafts, is braided and impregnated with Teflon or graphite...The packing can be flattened out, or un-braided...I have used pieces of packing on small valves like the ones on sediment bowls...when an O-ring was not available, or work...It's been a long time since I worked in a chemical plant, but globe valves, particularly those used in steam lines, use packing under the bonnet, or hex cap...A marine supply store would be a good source for the packing...
Respy, CarlsCAT
Tue, Sep 1, 2009 7:24 PM
OldNuc
Reply to CarlsCAT:
Respy, CarlsCAT
There are felt packing washers available and I suspect that a thick mixture of yellow beeswax and flake graphite could be used to soak them in and then squeezed out. Cutting square cross section commercially available valve or shaft graphite packing and winding into a ring would work also.
Tue, Sep 1, 2009 8:15 PM
Reply to CarlsCAT:
Respy, CarlsCAT
OH, I see.........you have a gate valve instead of a stop cock. Most of the ones I have been around have a 1/4 turn stop cock you use a wrench to turn. Your packing should work just fine as a stem seal. Many times just some string wound around will also work along with the remains of the old stem packing.
Tue, Sep 1, 2009 8:17 PM
CarlsCAT
I just took the bonnet off one of the old fuel valves...Used a 1 5/8" wrench...Rather than an adjustable wrench...There is a brass washer holding down "cord" packing...The cord is braided with graphite and cut at a 45 to complete the ring...
I have some leaky valves like this...but replaced them with newer cock-valves (available at hardware stores and such) to get the dozer operating without diesel leaking all the time... I will have to re-pack these old valves to put them back on the D2...
Respy, CarlsCAT
Tue, Sep 1, 2009 8:52 PM
