I have a 54 D47u I am rebuilding. Where do I find gaskets? Searching for the oil filter gaskets as they look too narrow to make and will probably need others. I do not think this machine has been apart in a very long time.. It took me 4 hours just to get the air filter oil bath apart and cleaned!
Have you checked with Cat? There are actually quite a few gaskets that are available through Caterpillar for the D315/D318, surprisingly enough
The Cat dealer has most of the gaskets for that machine as I have a D47U also. All you need is the correct parts book.
the oil filter and the oring seals are available from the dealer. last time i did a filter change the orings were in the box
filter should be 1r729
yours is the same vintage as my 6u
I have a 6U and found gaskets for the fuel filter tower at NAPA AUTO. They are listed as gas filters Napa part number FIL 5635. I paid $2.23 each. The filter cartridge are NAPA part number 3825. I paid $25 each for the 4 needed. I did not check Cat prices because the nearest Cat dealer is a 2.5 hour round trip and Napa is 10 minutes from me.
That is very helpful.. Thanks so much!
