Where to buy 1" hex
Where to buy 1" hex
Showing 1 to 10 of 12 results
reidrhollander
Send a private message to reidrhollander
My clutch plug and hydraulic fluid plug take what appears to be a 1" hex socket. Where can I buy one of these? Can you get them in 1/2" drive or only 3/4"?
Wed, Oct 28, 2015 10:54 AM
Thank you received: 112
Hi, Reidhollander.
You can make your own by welding a short 5/8 SAE bolt - fits a 15/16 wrench - to a piece of about 3/4" rod roughly 6' - 12" long to act as a handle. Or somebody on here will come up with a part # if you want the gen-u-wine ar-tickle. They can still be purchased from Cat dealers, at least here in DowNunder, either as a fitting for a 1/2' square drive socket handle or as the wrench version, both of which ackshully have two separate hexs on them, the one you are looking for and a smaller one.
Hope this helps.
Wed, Oct 28, 2015 12:31 PM
Thank you received: 52
Hi, Reidhollander.
Hope this helps.
Get one of these...Cat part #5S9569
Wed, Oct 28, 2015 12:48 PM
Hi, Reidhollander.
Kee-wreck-shun - one side of the standard tool is 1 1/8" hex which is the larger - and quite possibly the one that you want. The other side is the 15/16" hex more commonly found on smaller tractors. Sorry 'bout that.
I have seen one 1/2" drive socket wrench breaker handle broken using the type that Old Magnet has posted, but that is ONLY one in all the hundreds that I have seen undone.
Wed, Oct 28, 2015 2:26 PM
Crawler Dollars
Hi, Reidhollander.
http://www.ebay.com/itm/301736554960?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
http://www.ebay.com/itm/291560627543?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Made in Taiwan, but I have quite a few of their larger impact sockets and they have never failed me and the price is right.
Good luck,
Tom
Wed, Oct 28, 2015 7:02 PM
ronm
Reply to Crawler Dollars:
Good luck,
Tom
3 of these on ebay right now...all of them about as spendy as you would expect. (This is the cheapest one...)
http://www.ebay.com/itm/Caterpillar-T-6F-3703-Drain-Plug-wrench-CAT-dozer-tractor-tool-D2-D4-D6-D7-D8-D9-/381381776282?hash=item58cc20139a:g:YKwAAOSwT6pV2JvV
Wed, Oct 28, 2015 7:54 PM
reidrhollander
Reply to ronm:
[quote="ronm"]3 of these on ebay right now...all of them about as spendy as you would expect. (This is the cheapest one...)
http://www.ebay.com/itm/Caterpillar-T-6F-3703-Drain-Plug-wrench-CAT-dozer-tractor-tool-D2-D4-D6-D7-D8-D9-/381381776282?hash=item58cc20139a:g:YKwAAOSwT6pV2JvV[/quote]
Wow, may be the real deal but I think I would rather have a socket type as it take up less room in the box. But that is a cool wrench.
Wed, Oct 28, 2015 8:49 PM
ronm
Reply to reidrhollander:
Yep, the antique/collectible dealers get ahold of them & the price tends to shoot up...
Wed, Oct 28, 2015 9:24 PM
Reply to ronm:
That long handle type is useless when reaching through holes in belly pans.
Realize that the plugs are not straight hex. The hex is actually tapered so if you want full grip you need the tapered drive.
Wed, Oct 28, 2015 9:43 PM
Crawler Dollars
[quote="Old Magnet"]That long handle type is useless when reaching through holes in belly pans.
Realize that the plugs are not straight hex. The hex is actually tapered so if you want full grip you need the tapered drive.[/quote]
I have to wonder why Cat would have designed them with a tapered hex...so dirt isn't able to pack into the recess or if they're cast, perhaps they added 'draft' to the mold to make them easier to remove????
Other than those 2 reasons, tapered makes little sense to me...just my 2 cents.
Tom
Wed, Oct 28, 2015 10:21 PM
reidrhollander
Tom
[quote="Crawler Dollars"]I have to wonder why Cat would have designed them with a tapered hex...so dirt isn't able to pack into the recess or if they're cast, perhaps they added 'draft' to the mold to make them easier to remove????
Tom[/quote]
Probably the same reason my BMW motorcycle has a funky cap on the oil filler....so you are more likely to buy THEIR tool!
I just stopped by the Cat dealer and ordered one. I think it was $46 which I guess isn't bad considering it will last forever...
Wed, Oct 28, 2015 11:46 PM
