Where can one purchase a zenith carb kit????
Showing 1 to 10 of 16 results
StudebakerJim
Send a private message to StudebakerJim
Hello,
I need to know where one can purchase a carb kit and float for the Zenith (7935C) carburetor that is on my 1938 D2 pony motor.
Any Ideas out there?
Jim
Fri, Aug 10, 2012 11:19 PM
rjh-md
Check the top of your carb ,and see if it has a little round tag on it .Take the numbers on the tag to a good auto parts store ,and they should be able to match a kit to your numbers .
Also parts still maybe available form a cat dealer if you have a parts book to get the cat numbers .
Sat, Aug 11, 2012 12:12 AM
StudebakerJim
Reply to rjh-md:
7935C is the number on the tag. I have called Cat, I have called Zenith and others and it's like this never exsisted or it's obsolete. But yet a guy on ebay rebuilds them, so part have to be available somewhere.
Sat, Aug 11, 2012 12:26 AM
Reply to StudebakerJim:
See the "Sticky Note" posted on the front page at the top of the Discussion Forum
There are a couple of places listed in there to get the Carb parts you are looking for
Sat, Aug 11, 2012 4:07 AM
Reply to drujinin:
[quote="drujinin"]See the "Sticky Note" posted on the front page at the top of the Discussion Forum
There are a couple of places listed in there to get the Carb parts you are looking for[/quote]
Jim,
There are a few wear parts that are not in the carb kits, such as bushings, that have to be made if there is too much wear.
I had mine rebuilt at Farmer's Service (http://www.farmersserviceinc.com/carbrebuild.htm). Expensive, but they do a first rate job.
Ray
Sat, Aug 11, 2012 6:48 AM
Thank you received: 31
Jim,
Ray
Hi Jim,
I believe that some John Deeres have pony engines with similar carbs and that they have parts kits.
Tried the Search here but could not find the info from past posts on this subject. Someone listed the kit P/No's from the JD Dealer.
Hope this helps.
Sat, Aug 11, 2012 12:30 PM
chriscokid
Reply to edb:
Hi Jim,
Hope this helps.
the carb shop http://www.thecarburetorshop.com/TrackitsC.htm#TracCate
looks like you need kit #1036
Sat, Aug 11, 2012 7:03 PM
ol Grump
Reply to chriscokid:
Check with your local John Deere dealer, the diesel 720 and 730 used the same Zenith carb. If you're real lucky and find a friendly parts guy he can print out a copy of the carb breakdown. .handy for ordering parts. It's been several years but as I recall, the gasket kit was fairly cheap and that long thin tube that often gets stuck and broken was around $17.
Sat, Aug 11, 2012 8:15 PM
SpragueM
Reply to ol Grump:
None of my part numbers for the John Deere kit come up as valid anymore (AR13005R). Here is an e-bay listing for the carb kit , not mine and purely for informational purpose's.
http://www.ebay.com/itm/Pony-Motor-Carburetor-Kit-John-Deere-70-80-720-820-730-830-/390346680847
Matt
Sun, Aug 12, 2012 12:14 AM
John from Fresno
Reply to SpragueM:
Matt
Here is the current John Deere part number for the Zenith TU-4C carb. This is the kit for the D2 D4 D6 pony carb. If you have any of these tractors please take note of this part number and keep in safe place. So if you need a kit you will have the info handy.
John Deere RE528699
It was about $20 last time I bought one. Or you could pay more and get one of Ebay.
John
Sun, Aug 12, 2012 1:01 AM
SpragueM
Reply to John from Fresno:
John Deere RE528699
John
Part number RE528699 comes back as" Gasket set, Zenith carburetor for $17.93". RE528697 is Kit, Carburetor, Zenith for $272.85.
I cannot say what is in each kit. You can see what the one on e-bay contains.
Matt
Sun, Aug 12, 2012 3:53 AM
