where can I find dozer configuration #
jbeam
Send a private message to jbeam
Hello, I recently bought a D3B I have been going over it making repairs as needed, I went to get packing kits for the cyls ( I didnt aquire a part manual yet ) and the parts guy told me he cant order packing kits untill I give him my dozer arrangement#. Where in the world can I find this? I have serial #s for the machine, engine, transmission but I cant come up with a dozer # jbeam
Tue, Jan 4, 2011 10:34 PM
Thank you received: 52
Your parts contact should be more helpful than that. The controls are covered in the general parts catalog but the blade and parts are not. These are covered in a separate parts catalog covering your style of blade of which there are several. Most common on the D3 is the 3P version (power/angle-tilt) but there is also a straight blade, mechanical angle and LGP versions as well.
Along with your tractor model and serial number and a description of your blade the parts person should be able to match up the blade application and part numbers.
Sorry, I don't have the blade parts catalog in my collection.
Tue, Jan 4, 2011 11:13 PM
bluox
Thank you received: 12
Look on the R.H.side on back of blade. The parts book for a D3B will have all all the info under hydraulic system or implements.
Or call Cat dealer with serial # ,they can tell you.
Bob
Tue, Jan 4, 2011 11:55 PM
jbeam
Reply to bluox:
Bob
thanks guys, the D3B has the standard 6 way blade. The parts guy I am dealing with is no help unless I have the part # ready for him before I call. I need to get a parts manual for the machine .
Wed, Jan 5, 2011 12:08 AM
Reply to jbeam:
I suppose the D3B parts manual may be different but I have the manuals for the D3 79U and only the controls are covered...no implements.
Wed, Jan 5, 2011 12:39 AM
bluox
Did you check your blade for a #? May be a 85u #.
Each cyl. should have a group # on it.
If you are dealing with a Cat parts man you need to talk to the store manager.
Bob
Wed, Jan 5, 2011 1:28 AM
Reply to bluox:
Bob
When you figure it out don't buy from Cat if that's the way they treat you. Try this source:
http://www.baumhydraulics.com/files/catalog/sec-y.pdf
Wed, Jan 5, 2011 3:36 AM
jbeam-- i have a d3b--27y03729 with the 6 way blade. I have a parts manual and also have access to an online parts manual at my cat dealers website.
the id tag on the machine also has the arrangement numbers but i have never had to use them
I have ordered the front seals but haven't installed them yet
6j9733
4j8979
5j8150
2h3931
4j9224
most of these part #'s have been replaced with new #'s
Wed, Jan 5, 2011 4:07 AM
Reply to dpendzic:
6j9733
4j8979
5j8150
2h3931
4j9224
OK,
Think I figured out the parts book thing. Apparently you have to watch for the manuals that say bulldozer and list the bulldozers, rippers, etc. coverage. as opposed to those that just list the tractor and engine.
Wed, Jan 5, 2011 11:03 PM
