When was the first production Direct Start D4
chriscokid
What year was the first production Direct start D4 and which series was it?
May be a 7U 1958?
Wed, Aug 4, 2010 9:54 PM
Thank you received: 52
My info (7u parts book) shows DE start @7U28380 (1954)
The 6U would be at the same time.
This would still be as an attachment option.
Wed, Aug 4, 2010 10:14 PM
KCB
Send a private message to KCB
OM: Agreed, the 24V DE start was effective with 7U28380. However the starter hole machined in the flywheel housing started at 7U28232. Apparently it took the factory another month to get all the needed parts.
Not many 1954 (or even 1955) D4's had 24V DE start. The attachment must have been slow to be accepted, even though it was about $50 lower cost than the gasoline starting engine system. 24V DE was not recommended for ambient temperatures below 25 deg F (or below 15 deg F if ether aid was used).
[quote="Old Magnet"]My info (7u parts book) shows DE start @7U28380 (1954)
This would still be as an attachment option.[/quote]
Thu, Aug 5, 2010 9:03 AM
Reply to KCB:
Don't know about that explanation for delay. The Industrial engines had the 24v direct start option throughout the D315 production and prior also.
Could have been hung up on sheet metal and/or manifold changes I suppose.
Thu, Aug 5, 2010 10:35 PM
