what's this d69u
what's this d69u
bcguide
Send a private message to bcguide
so I think I am going to call this cat sensuous. it seem to be a case of since you was doing this I may as well....
anyhow I dropped the belly pan to clean it out and change the oils and I noticed a leak from the cover in tge picture
so I took it off and made a new gasket and reinstalled it and managed to breat the cover. I have repaired it and now having a better look at things I am wondering if
it is supposed to use the gaskets as shims to preload a bearing
it is the clean one of course
Mon, Sep 12, 2016 7:46 AM
rmyram
according to my parts manual, there is only a gasket between that cover and the housing behind it. the housing behind that cover shows having shims to set the endplay clearance of the shaft. those are roller bearings, not tapered cone bearings. your picture is also looking up from the bottom as the input shaft should be on top. just in case anyone else is trying to orientate the shafts correctly to chime in.
gasket number is 7b4570,
Mon, Sep 12, 2016 9:58 AM
bcguide
Reply to rmyram:
thank you
I have put it back together the way it is
Tue, Sep 13, 2016 5:47 AM
Earlcoate Charity Open Day
