What's this??
What's this??
Oldrnu
Send a private message to Oldrnu
Saw this advertised on CL as a 1950's D2. I have an early 50's D2 and it doesn't look much like this and the only spark plugs are on the pony motor.
Sat, Feb 18, 2017 12:56 AM
Thank you received: 140
Hi, Oldrnu.
That looks more like a 22.
Sat, Feb 18, 2017 1:03 AM
Jeff M.
Hi, Oldrnu.
it is a 20
Sat, Feb 18, 2017 1:31 AM
terrywelch_archive
Reply to Jeff M.:
it is a 20
I agree with Jeff it's a 20
Sat, Feb 18, 2017 2:10 AM
MARCOTEN
Reply to terrywelch_archive:
i am shore its a 28,
(the re-designed 20 and 25 as base machine but with some new modifications) as the back of the seat has the chopped of corners, and the radiator sideplates have Caterpillar on it, ( radiator plates of the 20 and 25 had twenty and twenty five on them)
Sat, Feb 18, 2017 2:57 AM
Reply to MARCOTEN:
I vote for the 28.
Sat, Feb 18, 2017 3:09 AM
Jeff M.
I vote for the 28.
the final drive hubs are small it could be a early 25 but not a 28 with the hubs so small
Sat, Feb 18, 2017 4:52 AM
Reply to Jeff M.:
Looks like 28 to me....
Sat, Feb 18, 2017 5:01 AM
naylorbros
Thank you received: 31
How about a mixture of parts. L/PL Twenty final drives by the sprocket cover, early L/PL engine lower side covers by the hooks for the early hood latches. Twenty Eight style engine by the later water pump and it looks like the radiator has Twenty Eight across the top take. Late Twenty Five/ Twenty Eight style seat and fenders. The fuel tank is also the Twenty Eight style as it uses no hold down straps like the L/PL Twenty does. The hood is also Twenty Eight style as it has the sliders and bolts at the back to attach it to the fuel tank, the P/PL used clips in this location that were spot welded to the hood. I can not remember what the Twenty Five had on the last two items as I have not looked at the parts book for the Twenty. Five in a couple of years That is just at a quick look
Ken
Sat, Feb 18, 2017 11:57 PM
