What’s the best way to source replacement excavator parts in Australia?
Showing 1 to 7 of 7 results
admindigger
Send a private message to admindigger
I’m curious what other Australian members are using when they need parts or attachments for smaller excavators. Do you normally go through the dealer, aftermarket suppliers, or look for used parts? I’m particularly interested in what’s worked well for rubber tracks, buckets and hydraulic attachments.
Tue, Oct 6, 2026 5:12 AM
Busso20
Thank you received: 31
I would suggest try ITR for parts they do carry rubber tracks some bucket pieces (not sure on complete buckets), aftermarket if common machine, generally good aftermarket company can keep good quality, Above all depends if you will use all day everyday or a couple of days a year is the factor to consider when purchasing anything.
Tue, Oct 6, 2026 5:17 AM
ChrisE
Thank you received: 41
We put EIE buckets on Kubota excavators. They seem to handle the abuse fairly well.
Thu, Oct 8, 2026 3:29 AM
admindigger
Reply to Busso20:
Thanks for the tip. That makes sense, especially the point about how often the machine is used. I guess it really comes down to balancing quality with cost.
Fri, Oct 9, 2026 11:48 AM
admindigger
Reply to ChrisE:
Good to know. How long have you been using the EIE buckets, and have they held up well over time?
Fri, Oct 9, 2026 11:49 AM
ChrisE
We have been selling Kubota excavators for 6 years and the main branch that bought us has done excavators for alot more than that. They are the go to because of their reliability.
Sat, Oct 10, 2026 2:39 AM
ianauz
Send a private message to ianauz
Thank you received: 5
Depends which state your in , Most states have Bucket and attachment builders/suppliers. Here in Queensland there is Jaws and Digger.
Be wary of new buckets at auctions . Lot of Chinese manufactured ones out there that fall short . My old boss bought a new bucket at auction . First day on machine had cracked welds
For rubber tracks,a quick google search should bring up local suppliers .
Sat, Oct 10, 2026 9:00 AM
Thank you received: 54
if your after new or used parts tillys at toowoomba have quite the selection they also buy and sell used machines as well as wrecking of machines not suitable for sale.
most of the larger engineering and fabrication shops will rebuild buckets. every mining town has one near by.
and their is nothing wrong with itr track components.
your local dealer is often a good source too.
for aussie made attachments for mini excavators and loaders try digga or norm engineering
Sun, Nov 15, 2026 6:36 AM
