Whats it worth?
Whats it worth?
Showing 1 to 6 of 6 results
Construction Bob
Send a private message to Construction Bob
I am new to this. I have 80 acres in southern Ohio that I think I need a small dozer for.I am not interested in spending lots of $$ for one. Just want it to move logs, creek clean up, and general grading etc. I have a massey 165 now and it won't do everything I want.I just saw this D2 5u on Craigs list and wondering if this is a good price or high. I know nothing about dozers and any information you can give me as to what to look for when going to look at one would be greatly appreciated. Thanks!
http://mansfield.craigslist.org/grd/2331984413.html
Sun, Apr 24, 2011 9:23 PM
It would be good if you can get the serial#---this will tell the year and if the main clutch is removable thru the top cover plate. You will also need to know the condition of the undercarriage as these components can be costly to replace. It appears to have the larger solid front idlers and good grouser bars.
Sun, Apr 24, 2011 10:11 PM
B4D2
Hi Bob. Welcome to the forum. This is as good a place as any to get sound advice on Caterpillar machines. That is a "late" model D2, so it has a little longer track frame than the earlier models. It also has the larger solid idler (front wheel) which will assist in better grading. Although the color is odd, it looks (from 4 pictures) to be in good shape. It has a Caterpillar 2S dozer blade with a #44 hydraulic unit. The idlers look to be far enough back on the track frames to indicate you have adequate adjustment and decent undercarriage. Take that with a grain of salt though. Some fellows used to take a link out of the track if the UC was well worn to try and get a few more hours out of it. A direct electric start is a nice thing, as you won't be fiddling with a pony motor. It's a love/hate relationship with the pony. For +$4700, I'd say your right in the ball park. I'd try to buy it.
Sun, Apr 24, 2011 10:13 PM
zootownjeepguy
In my opinion $4750 may be a bit on the high side. That all depends on the condition of the machine. If the tracks are good and tight I'd probably go for it (grouser height looks good). If it needs some work I'd keep looking. Some guys prefer direct electric start but I like pony motors (batteries can cause problems). Of course you'll have to repaint it YELLOW.👍
Rich Salvaggio
D2 5U9917
Sun, Apr 24, 2011 10:14 PM
B4D2
Reply to dpendzic:
It does look as if it is a late model, so chances are that it has the split coupling...👍
Hmmm, on looking at the pics again, those grousers look a bit tall. I'm wondering is somebody didn't weld on some extra bits to them. Still, I'd be negotiating with the seller.
Steve A
Reply to B4D2:
a D2 is a fun little machine, not much in the big work or grading department, I would sugest a D4 or better for real work
That being said I listed my D69U on Craigs list, I will list it here also later today
Mon, Apr 25, 2011 12:16 AM
d9gdon
Reply to Steve A:
Good looking D2 there. I know who the seller is and he's very trustworthy. He knows dozers. Looks like it's priced right. Even if it's a little high you can be sure it's been looked over.
Mon, Apr 25, 2011 12:29 AM
