What’s is considered acceptable oil consumption for an old cat?
Showing 1 to 10 of 15 results
DrewAbt
Send a private message to DrewAbt
Hello folks.
I have a 1965 D7E with a motor that was replaced 15 years ago due to a broken balancer shaft. The motor was from some sort of military power unit and appears to be the same specs as the original. It has good power and will not smoke anymore than normal. It will load right up and spin the tracks in any soil. The motor hours are completely unknown to me. My question is what is normal for oil consumption in a old 832 cu. in. Cat. This unit will use about 3-4 quarts over a tank of fuel during a long hard day in the summer. It does have a fair amount of blow by out of the filler cap. Enough so that I can’t really add oil to it while it’s running because it blows it back out to some degree (a little mist at least). The engine starts great with the glow plugs even when very cold. It starts right up at +5 degrees f. It will not start at any temp under 85 degrees without the glow plugs if it’s a cold motor.
Anybody else have a motor that uses oil like this?
Sun, Dec 30, 2018 1:24 AM
Thats a little excessive. Sounds like it may be time for sleeves and rings. If it was valves it would start hard and spit and sputter when cold starting. If you do decide to overhaul then have the heads checked anyway. Blowback from the filler tube is normal when adding oil when engine is running, just have to pour oil in fast and put the cap on quickly.
Sun, Dec 30, 2018 2:12 AM
Wombat
Donor
Different grades and brands of oil can also impact on oil consumption, I had a 270 D8H that had a rebuilt motor when I purchased it, it used 5 liters every 10 hour shift right from oil change to next oil change, was using series 3 30 as recommended, one oil change I used series 3 15w 30, oil consumption dropped off to about 10 liters to 250 hour interval, so continued to use it there after. EDB or Old Magnet might have the number, there is a % of oil consumption to fuel consumption ratio that is acceptable before it is deemed time to rebuild an engine, I was told years ago, think it was 2% for these old style engines, it may have been a lesser %, hopefully one of them will chime in with the correct number.
Wombat
Sun, Dec 30, 2018 7:45 AM
Cdcompton
Send a private message to Cdcompton
Reply to Wombat:
Wombat
Also go heavy with an oil stabilizer.... we run lucas oil stabilizer and it will really slow consumption down and also it will help blow by alittle. we had a stieger with an old cat v8 1160 that would use 2 gallon per tank of fuel while running a ripper even after an overhaul then we started running lucas and consumption droped to near nothing
Sun, Dec 30, 2018 8:46 AM
DrewAbt
Reply to Cdcompton:
I probably am at about 1% oil to fuel usage if it’s working real hard. Much less on the easy days. Currently I’m using 30wt diesel oil from a good source. I will try some additive also.
Thanks again.
Sun, Dec 30, 2018 9:14 AM
Sasquatch
Thank you received: 5
Reply to DrewAbt:
Thanks again.
For what it is worth, I had a great uncle that cut his teeth as an operator in the 1940's and worked on construction and roadbuilding jobs up into the 1980's. About that time my dad had bought an International UD-18 power unit engine for his sawmill, same as what was in the TD-18 crawler tractors of the time. He was a bit concerned about oil consumption and my great uncle told him that they used to let the old diesels of that size go until they burned 2 gallons of oil each day before they'd finally pull it from service and decide what they wanted to do with it (rebuild or replace). That sounds quite excessive to me, but he swore that's what they did. The old UD-18 never burned more than 2 or 3 quarts a day and we ran that unit on the sawmill every summer for 20 years and it never got any worse so we never dug into it to see how badly it was worn. Had blowby but started well with the gas/diesel switchover mechanism and had good power.
Sun, Dec 30, 2018 11:34 AM
Thank you received: 95
Reply to Sasquatch:
time to break out the popcorn again with the old "what is correct oil for these older engines"
Cat recommended, back in the day and still recommend a Straight 30 Weight Diesel Engine oil for these D300 Series Engines working in Normal temperature and conditions--adjust viscosity as needed for your local temperature.
Multi Grade Oils today have way more additives, BUT, often with less of the vital additive for flat tappet cam followers as they are generally aimed at later designed engines some with roller cam followers.
Basically when Cat released their Multi Grade DEO, Cat said Pre-combustion Chamber Engines are STILL to run Straight 30 Weight Diesel Engine oils--ambient temperature can change that, AND, Direct Injection Engines run Multi Grade Diesel Engine Oils.
An exception to this case in point that I was involved in was a 3208 Low Horsepower Truck engine in a Cat Lift Truck that was using excessive oil.
When I inquired of what oil was being used I was told Cat Multi Grade oils as per the instruction for DI engines---BUT the 3208 was designed before Multi Grade Oil recommendations came in by several years.
The engine was scheduled for removal and overhaul--I suggested to run the good old 30 weight DEO and amazingly the oil consumption cleared up. Sometimes all that is written is not correct--there can be variances as you can see.
Hope this helps.
Sun, Dec 30, 2018 12:02 PM
caterpillar13
Reply to edb:
Hope this helps.
like has been said try the oil.
back around 1960 cat used to say give the engine like a teaspoon of Bonomi cleanser to break the glaze on cylinder walls , maybe some old timers can give better info on this.
Sun, Dec 30, 2018 1:05 PM
Cdcompton
Reply to caterpillar13:
Also something to remember the early d339's were naturally aspirated with 2 compression rings and 1 oil ring on pistons then they throw a turbo on the same engine with no change to piston design.... also there is no valve guide seals on the heads so naturally these engines are going to use oil
Sun, Dec 30, 2018 9:11 PM
DrewAbt
Reply to Cdcompton:
Wow so 2 gallons a day was what a worn out unit used! I don’t feel so bad with my usage at half that. I just wasn’t sure if that was normal or not but it appears that they all used plenty of oil to some degree. Basically I need to add oil at the beginning of every day when I fuel it if it worked hard the day before.
Mon, Dec 31, 2018 8:00 PM
seiscat
Reply to DrewAbt:
Operation and Maintenance Instructions books are still available on ebay at times. These books are well worth the price and will save you time and money.
This is a page from my D7E book, the last paragraph is about when to fuel.
[attachment=52017]IMG.jpg[/attachment]
I always fuel, grease and top off the oil at the end of the day. You can check the oil with the engine stopped, just add oil until it is about 1 inch above the full mark and it will be on the full mark when the engine is running. By doing the servicing at quitting time you don't have to get your hands dirty first thing in the morning.
One gallon a day is okay, and by using some Lucas oil treatment that can even be lessened.
Craig
Tue, Jan 1, 2019 2:56 AM
