What year/sn range is this d7?
Showing 1 to 10 of 42 results
ThomasMueller
Send a private message to ThomasMueller
So I was gold panning today in the mountains in bc and came across this D7... I wanted to know the sn to look up the year just for curiosity, but the winch covers the plate on the back and I could not find any signs of the engine tag... It appears to have been grinder away and painted over so either it had an engine swap or some sketchy activity?... It has 5-3/4 bore cast into the engine block and the older large needle injectors... also sorry for the awful picture formatting this site does not seem to like iPhones, and I tried rotating them in my photo albums... Anyway thanks for any responses.
Sat, Aug 27, 2016 7:45 AM
7upuller
Hey Thomas,
It looks like a D7 3t to me. They were built from 1944 to 1955 if I'm correct. The 4t was an Army version and the 6t was a Navy version. The information plate with weights and sizes were used by the government. So that leads me to believe it maybe a 4t or 6t. Hope this helps...
Glen
Sat, Aug 27, 2016 8:13 AM
Thank you received: 52
Reply to 7upuller:
Hey Thomas,
Glen
Most likely a 4T built 1944-45.
Sat, Aug 27, 2016 11:00 AM
ThomasMueller
Thank you for the responses!!!
Sun, Aug 28, 2016 7:23 AM
catsilver
Reply to ThomasMueller:
3T I reckon, I believe the military 4T had H section chassis side rails.
Sun, Aug 28, 2016 5:34 PM
Reply to catsilver:
By parts book
7M5054-up, 3T1-2547, 4T1-up all use the same case and frame number 2F45
3T2548-up case and frame number changes to 3F4084.
Sun, Aug 28, 2016 11:20 PM
Orange4ever
Send a private message to Orange4ever
By parts book
It's definitely a drive clutch. by the tag on the side I would say it is a 4T military with a cargo winch
Mon, Aug 29, 2016 7:54 AM
Reply to Orange4ever:
Except that's a Isaacson winch not a Carco.
Mon, Aug 29, 2016 9:10 AM
mrsmackpaul
As cat silver says no H section chassis and the mud guards ( fenders for you blokes ) are pressed tin
I have seen chassis with the complete H section chassis and they are stamped 7M
Also looks like the crank handle for the pilot motor was once out the side not always thru the top what attachment needed it thru the side I wonder
Looks like a old 3 T to me
Also have been told that a 4 T wasnt built buy Cat but was out sourced back in the day the 3T was a Army machine in the Pacific dunno about this other stuff have never heard of it being a 4 T Army machine maybe that was only the US Army only thing
So much none of will never know now as most of us werent around back then or if we were we werent old enough or in a position to know
Paul
Mon, Aug 29, 2016 9:37 AM
Andrew
Reply to mrsmackpaul:
Paul
Dont want to rain on your parade Paulie my dear, but I feel definitely a 4T. now fitted with a front mounted PCU.
But originally fitted with LeTournau over head gear and most likely a rear mounted DDPCU.
Andrew K..
Mon, Aug 29, 2016 9:49 AM
mrsmackpaul
Reply to Andrew:
Andrew K..
[quote="Andrew"]Dont want to rain on your parade Paulie my dear, but I feel definitely a 4T. now fitted with a front mounted PCU.
Andrew K..[/quote]
You are most likely right Andrew LOL I reckon your 100% right about being a overhead gantry type set up
Who built the out sourced LeTournau PCU's and blades during the war as Im fairly sure all arent LeTournau but look almost the same only very slight differences than the genuine article and I think all parts are interchangeable
Paul
Mon, Aug 29, 2016 10:01 AM
