What year is my Holt ?
samato
Send a private message to samato
Hello all, new member here. I am trying to figure out what year this thing is. Does anyone know how I can find out? where is the serial plate etc?
Any help would be appreciated.
Sam
[attachment=52934]Holt2.jpg[/attachment]
[attachment=52935]holt1.jpg[/attachment]
[attachment=52936]holt3.jpg[/attachment]
Thu, Feb 28, 2019 11:44 PM
Bruce P
Thank you received: 21
Hello Sam and welcome!
Very nice looking Two Ton you have there.
There should be a tag on the engine near the magneto, and a tag on the tractor down around the gear shift lever.
Thanks for the pictures.
Bruce P.
Thu, Feb 28, 2019 11:53 PM
chuckb
Reply to Bruce P:
Bruce P.
hi Sam that is a beautiful tractor that has to be an early tractor with the riveted track frames the seat looks like a transition model from when holt and best merged in 1925 the early holts had the rounded seat back also the cutout letters on the radiator sides point to a early tractor again look for the bras plates they will tell the story
Fri, Mar 1, 2019 12:23 AM
Wombat
Donor
Reply to chuckb:
We must be grubs in Australia, how the hell do you have a workshop that looks clean and tidy like an up market restaurant or Rolls Royce showroom?
Wombat
Fri, Mar 1, 2019 2:58 PM
Thank you received: 27
Reply to Wombat:
Wombat
Hi Sam,
your tractor was originally known as the Holt T35 Tractor, Serial Numbers were 25,003-up.
As said above recognizable by the riveted track frames and bucket seat.
I believe they were released in 1921 and ran to 1924 when replaced by the Holt 2 Ton (T35), 70,001-up tractors with cast steel track frames. My Holt T35 Parts Book is Dated June 17, 1922. Form No :- P. L. 128
The link takes you to Swishy's 2 Ton site with a fair bit of information, movies, pictures and links, etc.
http://www.2tontractor.net/home
Scan is from Swishy's site and is a S/No list for both S/No T35's-- both Holt and Caterpillar 2Ton.
Sometimes the unit's approximate S/No can be guessed at by certain Part piece changes that were introduced at particular S/No's and/or removed.
More detailed photo's may help narrow it down a bit if your Engine S/No and Tractor S/No plates are missing.
Engine one is under the magneto mount area and the Tractor S/No plate is on the right side of the Transmission just below the gear shift lever--as someone kindly pointed out above.
Hope this helps.
Fri, Mar 1, 2019 5:22 PM
