what year 80c grader? also diesel in oil problem??
1941D4DOZERBOY
Send a private message to 1941D4DOZERBOY
Hi there, 80c cat 12 grader d318 engine? maybe you can verify that? Serial number is 80C892. Can you tell me what year this is and how diesel fuel can get into the engine oil?? I have a idea but id like to hear your ideas. Thanks friends!!
[attachment=56813]IMG_1452.jpg[/attachment][attachment=56814]IMG_1453.jpeg[/attachment][attachment=56815]IMG_1454.jpg[/attachment][attachment=56816]IMG_1456.jpg[/attachment]
Sun, Jan 19, 2020 6:46 PM
Thank you received: 62
80C0892 is a 1957 build with Direct Electric Start.
Usual cause of fuel in the oil is a leaking filter tower to injection pump fuel gallery 0-ring seal.
Sun, Jan 19, 2020 11:10 PM
josh
Thank you received: 14
Interesting that Peterson Tractor had their own serial number tag put on that machine, wonder if it was from new or part of a rebuild.
Sun, Jan 19, 2020 11:54 PM
Thank you received: 133
Reply to josh:
Hi, Josh.
Since the original serial number tag indicates a Chile build, I suspect that the Peterson tag would be a rebuild.
Mon, Jan 20, 2020 12:21 AM
Hi, Josh.
They weren't built in Chile, just where the trademark was registered.
Mon, Jan 20, 2020 12:41 AM
Correct, it says right on the top " Made in United States of America "
Mon, Jan 20, 2020 12:56 AM
Hi, Old Magnet and Rome K/G.
O.K., gotchya but................ I still suspect that the 'Peterson' tag is from a rebuild as I have never seen a ser. # tag with a dealer name on it on an original machine.
Mon, Jan 20, 2020 1:14 AM
1941D4DOZERBOY
Thanks friends!! Great info!! Yeah I think the engine was replaced also. With the Peterson number tag. I found that interesting also. Is that gasket number 4f5148? Also might replace the fuel filters part number 7b8264?
[attachment=56820]0E2B81FC-B185-480E-9E33-91AAFE2A901B.jpeg[/attachment]
Mon, Jan 20, 2020 2:47 AM
Reply to 1941D4DOZERBOY:
Yep 4F4158. If you order the filters from Cat and give them the old filter number it changes to four of 489-3196 filters and two 7B7635 gaskets.
Mon, Jan 20, 2020 2:53 AM
