What wt of transmission oil for D6 9U?
D6Rick
Send a private message to D6Rick
I'm confused about what the manual says for the wt of the transmission oil. It looks to me like like it says 30 wt but that seems pretty light. Maybe I'm not reading it correctly. Right below the 30 wt it says 80 & 90 wt but that appears to be referring to the final drives. Can someone straighten me out on this? Thanks.
Fri, Dec 21, 2007 7:53 AM
Thank you received: 52
It's normally 90wt in the transmission/bevel gear case and finals unless running in extremely hot temperature then 140wt. For below freezing the recommendation is 80wt.
Fri, Dec 21, 2007 8:06 AM
D6Rick
Thanks Old Magnet.
Sat, Dec 22, 2007 9:38 AM
